I didn't use a jun collar.
I took my r32 gtr crank to an engineering workshop and got them to machine the nose down and heat shrink a 4140 moly sleeve onto it.
They then machined it to r33 gtr specs.
They charged me $169 all up for everything but prices elsewhere could vary.
They can get most of the measurements they need from the r32 crank before they machine it down.
You just need to tell them how long to machine the flats.
If you go for a jun collar they still have to machine the crank and heat shrink it on.
got the collar with the pump...good price too...thanks CRD
so ill fit it...looks like the nose of the crank is machined and the collar is pressed on.
it comes with two grub screws so they will hold it in place.
I build my own engines.
thanks Nik (amaru)
I take it the grub screws are inserted 90deg from the drive faces (flats)?
The grub screws are just an extra precaution. You need to machine the crank to the right clearance (negative) for an interference fit.
Bob Lee at Action cranks has fitted squillions of them for a lot of engine builders.
when we do our we oil bath the collar also so its a little tighter on the tolerance (heat bath etc), but yeah as mentioned, machine the old drive off the crank, tolerance fit the new one, and drill grub screws on the flats of the drive ensuring they are bellow deck height, lock tite them in and your away.
Bingo, exactly what we did with our rb30det in the racecar. Except it was an rb30 crank obviously. Has worked with no dramas so far. I must say the drive section of the collar is massive in comparison to the std drive on the crank, well once again for rb30 crank lol. Bigger is better in these circumstances strangely enough.
It's a 2 thou interference fit. Then put the crank in the fridge and the collar in the oven and press it on. Temperatures normalise and it ain't going anywhere. Grub screws are just a precaution.
>_< cheers :wave:
Edited by Sydneykid
>_< cheers :wave:
some say to put the screws in on the flats...and others say 90deg from the flat face. Will a rebalance be needed??
We put them on the flats, I am not sure that it matters. They are also loctited in of course.
The diameter and weight of the flange is not really enough to put the crank out of balance.
That said, I always check the balance of RB cranks every time I disassemble an engine. It’s cheap insurance.
>_< cheers :wave:
:wave: cheers :wave:
Yeah...same...will balance after collar fitted
FOr the 30 mins it takes to check the balance we always do it!! I have never put the screws on the round side always on the flats, dont think it matters as mentioned there a precautionary measure.
We dont need a freezer in canberra just leave them outside in the morning in winter in canberra and bingo you have a crank thats -4 in temp!!!hahaha
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
