This is the plan .
Build an R31 with a VH41DE ( Nissan V8 4100cc )
Heres what i have .
I bought a VH41DE half cut for $ 1750 delivered
Bought the wagon for off ebay for $ 900 . It has a mint body . Replaced the diff ( $ 80 ) , replaced leaky water pump ( had a spare ) . Got it registered 3 weeks ago .
I plan to keep it looking as stock as possible , even down to the hubcaps .
Am only interested in going fast in a straight line , drags and on the salt flat .
Deliberately chose the 4100 cc engine to suit the class ( F = 3000 - 4300 cc ) i want to run at the salt lake speed trials .
Edited by dondesoto
https://www.sau.com.au/forums/topic/126859-vh41de-into-r31/
OK . Here is a pic of the wagon i raced this year at Lake Gairdner speed trials . Was running a RB30DE . Best average speed over 1 mile was 141 .187 MPH ( 227.21 kmh ) . I saw 152 MPH ( tacho reading ) at the end of one run . Engine basically stock with 370 cc injectors , extractors and 2 x rb25 throttle bodies , apexi safc 2 , and thats it . Standard cams and head .... NON TURBO
Edited by dondesoto
https://www.sau.com.au/forums/topic/126859-vh41de-into-r31/#findComment-2342582
Nice work on getting the VH41DE.
What sort of Gearbox did it come with? Auto or manual? and what sort of box will you be using?
do you plan on modding the engine or running it stock? How much will it set you back to cet the new engine in and running in the car?
Is your other R31 with the RB30DE for sale :(
https://www.sau.com.au/forums/topic/126859-vh41de-into-r31/#findComment-2342808
only ever seen them with auto's behind them... AFAIK they didn't get sold with a manual option..
and every combo we've tried doesn't work, rb/vg/sr etc boxes all have a different bell housing setup, the VQ boxes might go but not sure..
however locally in perth someones developped an adaptor plate to slap a 25 box behind it, well any RB box really, but 25 for the strength, needs a custom flywheel, but its workable, PM me if you need more info on who to speak to
https://www.sau.com.au/forums/topic/126859-vh41de-into-r31/#findComment-2343421
Mods will be limited to extractors ( home built ) , cams if i can get the stock cams ground , malpassi fuel pressure reg , Apexi safc 2 and a decent air intake .
I will be doing the installation myself and am going to tackle the wiring up too .
I will be using the auto box the engine come with , cheapest and easiest option for now . Fitting an rb25det box would be a good option , but but would cost more than my whole half cut by the time its fitted .
The red car is not for sale yet, as it will still be my daily driver until i finish the blue cars conversion . Hoewever will be selling the rb30de engine at a latter date , maybe towards the end of the year .
Its not a priority but it would be nice to have it all done for a total of less than $ 5000 ( including purchase of car and half cut ) . 150 Mph + for less than $ 5000 , i like .
Edited by dondesoto
https://www.sau.com.au/forums/topic/126859-vh41de-into-r31/#findComment-2343723
Spent many hrs on saturday , disecting the harness . had pulled out all engine bay harness and in car harness . Massive amounts of wiring . Found a total of 6 computers . Only using 2 of the computers , engine management and auto trans . Believe i have all the wiring i need after chopping out one big box full of surplus wiring and electricals .
https://www.sau.com.au/forums/topic/126859-vh41de-into-r31/#findComment-2351061
Good luck, the wiring is probably the hardest part of setting something like that up.
https://www.sau.com.au/forums/topic/126859-vh41de-into-r31/#findComment-2351209
it is, took my mate a few solid nights and some weekend time to sift thru everything tracing wires to see where they went and what they hooked into, the amount of surplus in the looms is astounding..
AH tell me about it . Have spent many hours unravelling harness . Thought i had it right , then discovered i had chopped out 16 wires too many that go to the transmission ecu , a big BUGGA . Have had a lot of help from NICO forum in sorting that prob out .
  • Like 1
https://www.sau.com.au/forums/topic/126859-vh41de-into-r31/#findComment-2357397
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
