This is the plan .
Build an R31 with a VH41DE ( Nissan V8 4100cc )
Heres what i have .
I bought a VH41DE half cut for $ 1750 delivered
Bought the wagon for off ebay for $ 900 . It has a mint body . Replaced the diff ( $ 80 ) , replaced leaky water pump ( had a spare ) . Got it registered 3 weeks ago .
I plan to keep it looking as stock as possible , even down to the hubcaps .
Am only interested in going fast in a straight line , drags and on the salt flat .
Deliberately chose the 4100 cc engine to suit the class ( F = 3000 - 4300 cc ) i want to run at the salt lake speed trials .
Edited by dondesoto
https://www.sau.com.au/forums/topic/126859-vh41de-into-r31/
OK . Here is a pic of the wagon i raced this year at Lake Gairdner speed trials . Was running a RB30DE . Best average speed over 1 mile was 141 .187 MPH ( 227.21 kmh ) . I saw 152 MPH ( tacho reading ) at the end of one run . Engine basically stock with 370 cc injectors , extractors and 2 x rb25 throttle bodies , apexi safc 2 , and thats it . Standard cams and head .... NON TURBO
Edited by dondesoto
https://www.sau.com.au/forums/topic/126859-vh41de-into-r31/#findComment-2342582
Nice work on getting the VH41DE.
What sort of Gearbox did it come with? Auto or manual? and what sort of box will you be using?
do you plan on modding the engine or running it stock? How much will it set you back to cet the new engine in and running in the car?
Is your other R31 with the RB30DE for sale :(
https://www.sau.com.au/forums/topic/126859-vh41de-into-r31/#findComment-2342808
only ever seen them with auto's behind them... AFAIK they didn't get sold with a manual option..
and every combo we've tried doesn't work, rb/vg/sr etc boxes all have a different bell housing setup, the VQ boxes might go but not sure..
however locally in perth someones developped an adaptor plate to slap a 25 box behind it, well any RB box really, but 25 for the strength, needs a custom flywheel, but its workable, PM me if you need more info on who to speak to
https://www.sau.com.au/forums/topic/126859-vh41de-into-r31/#findComment-2343421
Mods will be limited to extractors ( home built ) , cams if i can get the stock cams ground , malpassi fuel pressure reg , Apexi safc 2 and a decent air intake .
I will be doing the installation myself and am going to tackle the wiring up too .
I will be using the auto box the engine come with , cheapest and easiest option for now . Fitting an rb25det box would be a good option , but but would cost more than my whole half cut by the time its fitted .
The red car is not for sale yet, as it will still be my daily driver until i finish the blue cars conversion . Hoewever will be selling the rb30de engine at a latter date , maybe towards the end of the year .
Its not a priority but it would be nice to have it all done for a total of less than $ 5000 ( including purchase of car and half cut ) . 150 Mph + for less than $ 5000 , i like .
Edited by dondesoto
https://www.sau.com.au/forums/topic/126859-vh41de-into-r31/#findComment-2343723
Spent many hrs on saturday , disecting the harness . had pulled out all engine bay harness and in car harness . Massive amounts of wiring . Found a total of 6 computers . Only using 2 of the computers , engine management and auto trans . Believe i have all the wiring i need after chopping out one big box full of surplus wiring and electricals .
https://www.sau.com.au/forums/topic/126859-vh41de-into-r31/#findComment-2351061
Good luck, the wiring is probably the hardest part of setting something like that up.
https://www.sau.com.au/forums/topic/126859-vh41de-into-r31/#findComment-2351209
it is, took my mate a few solid nights and some weekend time to sift thru everything tracing wires to see where they went and what they hooked into, the amount of surplus in the looms is astounding..
AH tell me about it . Have spent many hours unravelling harness . Thought i had it right , then discovered i had chopped out 16 wires too many that go to the transmission ecu , a big BUGGA . Have had a lot of help from NICO forum in sorting that prob out .
  • Like 1
https://www.sau.com.au/forums/topic/126859-vh41de-into-r31/#findComment-2357397
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
