hey guys
been doing lots of reading and searching through archived threads and also talking to friends in japan also...
my old rb20 i decided to take the head off to really look at what damage was done by the transport company... piston 4 rings are totally gone and some nice scores in that piston... apart from that everythingelse is dirty but looks to be ok (especially cyl bores)
looking to do an rb24 conversion using 26 crank and rods... before i send it anyway i do want to shop around and get most parts myself to make it easier for my builder and cheaper for me
rb20 complete engine - check (still turns over... on 5 cyl :wave: )
n1 oil pump
n1 water pump (both of which fit correct?)
when looking at crank and rods what are the differences between 32/33? i have a friend who has 33 crank and rods in really good nick with no fractures... and i understand the gtr 33 crank has benefits inregards to the oil pump drive?
and the 2 big questions... pistons (4agze forgies will suffice? i have looked into the tomei .82 rb24 pistons which are a bit under 2k delivered from JP) and headgasket? what to use? could not find the tomei rb24 headgasket on the site... custom?
also any other recommended bits while im at it? i want to do this once and do it properly... working 56hour weeks is hurting also just to pay for it!
this motor will be running a td06-20g 8cm ext gated setup with ap eng rb20 power fc (already have this)
any help is much appreciated guys... its been a while since ive fiddled with internals (takes me back to motor school)
thanks!
Edited by Hella Flush
https://www.sau.com.au/forums/topic/126903-rb24-time/
have you looked at the rb30det project? will probably cost less and youll get more displacement. also no need for n1 water pump, it flows less at lower rpm compared with the stocker, its only useful for track cars
https://www.sau.com.au/forums/topic/126903-rb24-time/#findComment-2344282
track only build up here no rego... thus from my understanding the flow efficiency at higher rpm was better?
ive tossed up the rb30 and even 25 to 26 idea... even a 26 itself... im happy with rb24... its a loyalty i have to the engine... and externally nothing will have to change
https://www.sau.com.au/forums/topic/126903-rb24-time/#findComment-2345038
i dont know why... mates saying 25 25 25... and do a 26 stroker... as we have a spare 25 at his place... but for some reason i just want to stick with the 20... the heads are nowhere near as efficient and with alot of head work you can get close (id say on est around 75% to the flow of a 25/26 head) but still something about them... they were the original RB... they have a long history and have certainly satisfied/assisted alot of the great track drivers we know today (both drift/drag)
rb20 block FTW!
https://www.sau.com.au/forums/topic/126903-rb24-time/#findComment-2345108
I hear ya there is also the RPM issue compaired to the 20/25 or even the 30 I know someone who has a rb30et in a R31 and he said doesnt come close to the rb20det he is even selling the engine and putting a 20 in instead.
https://www.sau.com.au/forums/topic/126903-rb24-time/#findComment-2346657
As some of the guys have already posted, an RB30DET is truly a better proposition. I have almost all of the parts necessary to do an RB24, have had for a number of years. But when I add it up the RB30DET costs less (build and run) and has far greater attraction (now and potential later on).
My RB31DET (3.1 litre) produces the same power at 7,500 rpm as an RB24 does at 9,750 rpm. I don’t need high duration cams or solid lifter conversions or mega valve springs for 9,750 rpm, for 7,500 rpm I really don’t need much at all. Standard water pump is fine, no change to the diff ratio required, I don’t need to gear down the alternator or the power steering pump. With much milder cams and 30% more capacity I don’t need to rev the beegeesus out of it to go fast. I don’t need to launch it at 7,500 rpm to avoid the bog down, so the clutch lasts a heap longer.
Having done it many times, I can assure you when you add it all up, the RB30ET is a much more logical route to take.
:D cheers ;)
PS, take a look at the HPI R32GTST 4 door for sale, it has an RB24 in it.
https://www.sau.com.au/forums/topic/126903-rb24-time/#findComment-2346825
I agree with you hella , The old rb20det have been a good engine and there are other options and many arguments about fitting bigger engine's BUT how many realy quick rb20's are out there in Australia.There's plenty in japan but jack shiet out here I have an rb25 sitting in the shed and everything to build a quick one including the forged 40thou oversized pistons and rods one day i'll get to it .but I aim to get my new car running better than the old R32 I had and it was running big hp numbers on a stock bottom end and some pretty good times down the quater mile at wsid to and would have gotten better. My aim is to get an rb20det powered R32 down the quater in an 11 sec run and i got close with the old car .Im with silv and roy go the rb20
cheers Peter
https://www.sau.com.au/forums/topic/126903-rb24-time/#findComment-2348916
LOL...any "what to do to my RB20 thread" always turns into a "do an RB30" :)
I think SAU often tends to talk down how much things cost. A few smart mods to an RB20 will make a for a quick and fun car. I for one find it more fun to spend say $2000 on mods and $3000 taking it to the track and flogging it. Better then 5k on the engine and not having any money to enjoy it :)
If you can afford to do both then i want your job :devil:
Also, on the stroker thing. What is the pin height on an RB20 piston comapred to RB26 and RB25?
It would be very cheap to grab RB25 or 26 crank, match it up with RB25 or RB26 rods and use them with the std RB20 pistons. It would be very cheap, give you more stroke and torque, without as much machining and expensive pistons and mods to head. Im thinking about doing somehting silimar with my spare RB20 :spank:
https://www.sau.com.au/forums/topic/126903-rb24-time/#findComment-2349264
LOL...any "what to do to my RB20 thread" always turns into a "do an RB30" :devil:
I think SAU often tends to talk down how much things cost. A few smart mods to an RB20 will make a for a quick and fun car. I for one find it more fun to spend say $2000 on mods and $3000 taking it to the track and flogging it. Better then 5k on the engine and not having any money to enjoy it :spank:
If you can afford to do both then i want your job :)
It would be very cheap to grab RB25 or 26 crank, match it up with RB25 or RB26 rods and use them with the std RB20 pistons. It would be very cheap, give you more stroke and torque, without as much machining and expensive pistons and mods to head. Im thinking about doing somehting silimar with my spare RB20 :)
I thought of doing that, but at 2,060 cc's with an RB25 crank and 2,120 cc's with an RB26 crank is it really worth the effort? Last time I looked, 4AGZE pistons where pretty damn cheap.
:) cheers :)
https://www.sau.com.au/forums/topic/126903-rb24-time/#findComment-2349358
:) cheers :)
But the pistons, though cheap still csot what. $400-600? Plus the machining and gudgeon pin mods, mods to the combistion chamber etc etc.
It may only be a few extra cc but the stroke could bump up the torque a little everywhere. You would think the stroke increase would do more then any displacement increase from boring the engine.
https://www.sau.com.au/forums/topic/126903-rb24-time/#findComment-2349565
    • Thanks for the reply mate. Well I really hope its a hose then not engine out job
    • But.... the reason I want to run a 60 weight is so at 125C it has the same viscosity as a 40 weight at 100C. That's the whole reason. If the viscosity changes that much to drop oil pressure from 73psi to 36psi then that's another reason I should be running an oil that mimics the 40 weight at 100C. I have datalogs from the dyno with the oil pressure hitting 73psi at full throttle/high RPM. At the dyno the oil temp was around 100-105C. The pump has a 70psi internal relief spring. It will never go/can't go above 70psi. The GM recommendation of 6psi per 1000rpm is well under that... The oil sensor for logging in LS's is at the valley plate at the back of  the block/rear of where the heads are near the firewall. It's also where the knock sensors are which are notable for 'false knock'. I'm hoping I just didn't have enough oil up top causing some chatter instead of rods being sad (big hopium/copium I know) LS's definitely heat up the oil more than RB's do, the stock vettes for example will hit 300F(150C) in a lap or two and happily track for years and years. This is the same oil cooler that I had when I was in RB land, being the Setrab 25 row oil cooler HEL thing. I did think about putting a fan in there to pull air out more, though I don't know if that will actually help in huge load situations with lots of speed. I think when I had the auto cooler. The leak is where the block runs to the oil cooler lines, the OEM/Dash oil pressure sender is connected at that junction and is what broke. I'm actually quite curious to see how much oil in total capacity is actually left in the engine. As it currently stands I'm waiting on that bush to adapt the sender to it. The sump is still full (?) of oil and the lines and accusump have been drained, but the filter and block are off. I suspect there's maybe less than 1/2 the total capacity there should be in there. I have noticed in the past that topping up oil has improved oil pressure, as reported by the dash sensor. This is all extremely sketchy hence wanting to get it sorted out lol.
    • I neglected to respond to this previously. Get it up to 100 psi, and then you'll be OK.
    • I agree with everything else, except (and I'm rethinking this as it wasn't setup how my brain first though) if the sensor is at the end of a hose which is how it has been recommended to isolate it from vibrations, then if that line had a small hole in, I could foresee potentially (not a fluid dynamic specialist) the ability for it to see a lower pressure at the sensor. But thinking through, said sensor was in the actual block, HOWEVER it was also the sensor itself that broke, so oil pressure may not have been fully reaching the sensor still. So I'm still in my same theory.   However, I 100% would be saying COOL THE OIL DOWN if it's at 125c. That would be an epic concern of mine.   Im now thinking as you did Brad that the knock detection is likely due to the bearings giving a bit more noise as pressure dropped away. Kinkstah, drop your oil, and get a sample of it (as you're draining it) and send it off for analysis.
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
