hi guys i got a rb26 with a n1 block thats is getting full rebuilt with internals
cp pistons rods cams blah blah and so on. i have heard that the n1 block is lighter but weaker does any1 have any input as car will be tuned around 400-450 rwhp in my cefiro and used for street/drift use
does any1 no how much power the n1 block can handle as i dont want to go all out with my rebuild to have the block crack???? any comments would be great thanks
https://www.sau.com.au/forums/topic/126938-n1-block-vs-stanard-block/
  • Replies 40
200000km old stocker is gonna be stronger than a new n1 block.
a 200000km old n1 block would be very strong
it comes down to weathering of the block/metal.
it worked for the 1400hp 1.5litre bmw f1 turbo engines :domokun:
if you can find a virgin bore old 32 block its gonna be plenty strong.
give advan performance a call. hes done some research on the issue i believe
or id just like to get my hands on a group A block :)
or id just like to get my hands on a group A block :(
Apparantly 2-5 unused blocks have found their way on to the market in Sydney in the past few weeks with a going price of $7000ish. Just what I have heard from a couple of people though, unsure how true it is if you actually went to buy one.
for 7000 i would be looking into a custom made block, place in adelaide is looking into (or made) billit SR blocks and billit SR inlet manifolds, blocks were going to be around 5000 i think.
How much stronger would something like that be?
I am no expert but would be greatly stronger as you can add material where you like, run no water galleries if its a drag car, more studs in bottom end caps/girdle. Tie in the end caps fromt he side of the block as well. As its custom you dont work around things that the factory had to like cost etc. I have seen a 1UZ (i think was in zoom) custom billit block as they were splitting the stock blocks.
Also off the top of my head there was a custom 4 cylinder motor made for a drag can in the USA, custom billit block running nitro, It was new set up as he was using motec and going to run in some sports compact class (cant rember details hopefully someone can post a link to the video) something like 2000 hp is i remember correctly.
http://www.google.com.au/search?hl=en&...earch&meta=
that is a link to the 1UZ block but im not a member of lextreme to view...
http://www.turbomagazine.com/tech/0202tur_...nnycar_integra/
that link for for the nitro 4 cylinder, 4000 hp, it says the block of alloy is over 1000 dollars by its self, im not sure how much machining would be if it would be under 7000. They have no coolant or oil drain back so for anything other then drag for a few seconds its no good.
I was just saying for 7000 for a block it opens up a few more options.
Edited by GTR1993
but does it chirp 2nd?
haha, thats pretty impressive reading.
Just Jap have a Group A block for sale. I'm pretty sure you won't find a brand new n1 block in Australia.
But who breaks a standard block unless you are making 11tybillion kw or bored it out over 87mm?
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
