  • Replies 112
Posted Images
nah it sounds about right, the rev limit is at 7000 but what the ecu see and what the tacho see are two different things. it probably did reach 7800 at once stage, if you just keep bouncing and trying to make it, it will probably get there. i also get 3 different rev and speed settings from hand controller, rsm and stock tacho and speedo
I got about the same k's as you paul. I filled up in hoppers before i left on sat morning n got 200k's n used 1/4 of a tank when we got into shep, then had half a tank left after D4D and got home just under 1/4 left and had done 430k's so i would have gotten around the same as u easy.
For sure mate! It'll be great to see the old holden sideways. Just make sure it's got a locked diff and you'll enjoy yourself. Just do it for the fun of it, because your car will be the limiting factor. Give it a go!
haha, ya the car is gonna be a big factor in being gay, altho will be out there to have a ball, not to compete, its all about the fun, and socialising etc :)
its got a fkn tite assed mechanical lsd in er, recently rebuild n shit ... its nice :wave:
mite take a while, damn money holding me back !!!
Go the Lada!! :D
So who photoshopped the smoke in there :D
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
    • Fuark, at least the motor survived. What brand was the fitting that snapped?
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
    • Measure voltage at the starter solenoid terminal when the key is at start and it has clicked. If it is really low, then the suspicion falls on the ignition switch (contacts or wiring thereof) as causing a voltage drop instead of sending enough volts to throw the solenoid all the way to engage the starter itself. If it is a decent voltage, then the suspicion is on the solenoid. Might have s horted coil, or might hva dirty contacts. Rip the starter off, dismantle, clean up contacts and inspect winding. It might not be possible to see if there is a short in the winding though. I have a spare starter here that I could measure the resistance of the coil, as a guide to about what it should be, if you need a comparison. <parts hoarder>No you cannot have it.</parts hoarder>
