Yeah that's true...
I guess if your pulled over for a breath test, there's less chance of them wanting to go over your car than if your seen giving it a squirt at the lights. Common sense really.
I think my area the cops mainly target V8's. There are a few P plate skyline owners, but yeah. None have been done that I know anyways. If they ever do it's just defected for other things.
EDIT - As for the 32, I would consider a GTR... but they're just further over than the 33 GTST's :(
Edited by ReeceR
  • Replies 56
ok let me settle a few things
a) Rego sticker weights are full of shit!... they mean nothing and have no reference to anything, they have been made up on each car eg. myself and my best mate both have 1994 r33 gts-t's mine is white his is black, only difference... his rego sticker says 1450, mine says 1370 ....
b) cops who suspect you of being over power/weight arent going to be stupid enough to just look at your rego sticker, they will pop the bonnet, it is well known r33 gts-t's are voer the power/weight and police will check the plates on your engine/firewall for the magical "rb25det"
in exact words from when i got done "mate your driving an rb25det in an r33 gts-t, if you want to drive a turbo'd skyline your gonna have to get an rb20 in an r32"
if they dont know, they wont fine you, and will most likely let you off with a defect, or just a lisence check/breath test
my rego sticker says my s2 r33 weighs 1600kg right on the mark for a p plater to drive. only found this out as my brother got done in his s1 r33 for power to weight 1450kg. it doesnt apply to me as i'm 25 but have a look around you might get lucky.
finally getting my car back this week after 6 months off the road YAY! :(
lol and according to vic roads, my car weighs 1200kgs
what part of, the cops dont go by the weight the rego sticker says. dont you understand.
im mates with someone who works for vic roads, he told me cops dont evcen work in co-ordination with vic roads for most stuff like power to weight fines etc. they go by there own judgement. not what vic roads says.
so judging it by your rego sticker, will not help you. you will still get done for power to weight if you drive an R33 gts-t on p plates. end of story.
well i think its obvious the sticker is wrong...and given the fact that its well known ALL R33 GTS-T's are over the limit
my cousins VX clubsport has about 1250kg on the rego sticker....and i think we know thats a very ambitious figure....
my NA Supra had 1100KG
my TT Supra has 1510KG
It's a good point... If the sticker said it's a GTS, then they surely couldn't fine me for driving a GTST? (Even if it is, how would they be 100% sure).
do u have a plaque mounted in your engine bay saying what engine u have?
some cops carry around p plater ban lists which includes the car that is banned + the engine in it
obviously if they see RB25DET then ur screwed
i know this cause i got done for the power to weight ratio, cop saw i was drving a Supra RZ with 2JZ-GTE written on the plaque mounted in the engine bay and came a $110 fine for me
im assuming u were on ur Ps?....if so wat the hell is a cop doing telln UUU how to get around the laws to drive a turbo.....P platers cant drive anything with a turbo/V8 i thought?
newai.....
just dont drive like an idiot.......and dont draw attention....i rkn thats the best advice anyone can give u.....if ur plannin to drive a skyline on ur Ps......although its hard enough as it is....
if u really do love the car......why should anyone stop u........just remember its a privlidge and not a right.....so if u sscrew around....prepare to lose ur car.
good luck!
Edited by anDru
An RB20 in an R32 is under the power to weight ratio, therefore it is LEGAL for P platers to drive.
i thought anything with a turbo is illegal full stop...even if it couldnt beat a turtle?
Doesnt matter whats on the rego sticker.
Its the FACTORY weight that it works from, not your claim from a donkey rego sticker
They can surely fine you for it. Your driving a GTS-t, you can be fined for it.
Its not up for debate, and there is no "cheat" to get around it.
What your rego stick has means d|ck all, especially when the build plate in the engine bay has the engine specification.
Thread closed. There is more than enough info here on the forums, in the sticky threads.
And failing that you can always ring VicRoads or get onto thier website which also lists all the information
Thanks
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
