Hi Guys, I just replaced my O2 sensor on my R32 GTS-t with an EL Falcon replacement as reccomended here but it is idling like crap so I unplugged it and it is fine again...
I am guessing that I got the wires wrong.
The R32 Sensor has Black, Red and White
The EL Falcon Sensor has 2 White and a Black.
I am guessing that the black goes to black? The others I just copied the output from the R32 sensor (red was top right and white was top left)
I am guessing I have them wrong, can someone tell me what is what??
Thanks!!
Todd
https://www.sau.com.au/forums/topic/127517-el-falcon-o2-sensor-on-r32-gts-t/
  mad082 said:
i would've been easier to buy a r32 o2 sensor. they are a bit more (about $110 from autobarn for a NGK), but they plug straight in.
How much is R33 o2 sensor from there?
I also heard u can use EL falcon on R33... btw Paul33 might know how to fit them.
My Ford sensor had two white and one black. The black was the signal wire, and the two white were the heater wires.
My R33 plug had the same thing, but different colours. Could have been two black and one red. Can't remember, but they all hooked up fine.
Thanks but I don't think so. once it started playing up (after I put on a new dump pipe), I unplugged it to bypass the problem.
Thanks for the info about the wires. As stated the ford one that I have also has 2 white and 1 black wires.
The r32 sensor has a black, red and white. IS ANYONE ABLE TO TELL ME WHAT IS WHAT??
Thanks for your help so far!
  RANDY said:
Maybe someone adjusted your idle air control valve when your 02 sensor was dead? So when you plug it in, it's running correctly, but your adjustment is outta whack? Dunno. Just a guess.
I would wager a guess that the black and red both go to black, and your white wire goes to the black on on the 02 sensor. Still, dunno... someone will give you the answer though! You definately got the right one for your car, yeah?
Todd even though it is a cop-out, there are only three different ways to connect the sensor, given that the signal wire can only go in three different terminals and the heater wires are irrelevant. (and as Randy said, black = signal, white = heater). If you don't receive an answer, try trial and error and use a voltmeter to test the signal output. If you're in Sydney I can help out with a Consult cable.
As an outside chance, did you reset your ECU after installing? You'll need to clear the fault codes otherwise the ECU will most likely consider the sensor to be still broken and it'll revert to the run-rich ECU maps.
So I am guessing keep it how it is, plug it back in and reset the ECU? If I still have the problem I will try swapping them around!
Would still be great if someone could tell me for sure... surely someone has done this to an R32 before.
Thanks guys!
I've changed my O2 sensor with an EL Ford one as well, my experience with connecting things up was the same as Randy's. After an ECU reset the car ran fine (and still does). :) Would it be fair to say that the middle of the 3 wires is the signal, the other two are the heater wires? (pretty sure that's how mine was).
the el 1 is cheaper, but you have to wire it up.
i haven't done the research, but you have to take into account that if the sensor has different resistance and power then it can give the ecu false readings. for the extra money it is worth sticking with the proper one.
i know that the r33 unit is the same as used in the sr20 in the SSS pulsars and nx coupes (same part number). not sure if the rb20 is the same, but i think it might be.
Quick question.
My car has an aftermarket computer. (Link)
Recently it has suddenly started getting worse fuel economy. Could it be my oxygen sensor, or does my ecu somehow not utilise the factory O2 sensor anymore?
It's probably a basic question, but I'm not mechanically minded!
Please reply, I'm sick of getting ~100kms less per tank then I was a few months ago!
If it's not likely to be the sensor, what else could be causing my sudden pathetic fuel economy? It literally turned bad over night.
Thanks :ninja:
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
