Dropping the filter at 5k is a waste of time IMO. Unless you've got problems with your motor, it wouldnt even be 20% full of debris. Actually the longer you leave the filter on, its single pass efficiency increases (ie the better it actually filter out small particles) so I say, leave it on!
EDIT - I like this summary: "When time comes to change the oil at 3000-5000 miles they may just be getting in to their most effective part of their life cycle. Hence they never function optimally, or spent far less time in that range where small particle filtering is most effective."
Edited by Busky2k
Yep 300V has a stout additive package + high quality ester base oil = excellent recipe. Good thing its cheaper than Redline too. But for your average Skyline its wayyy overkill.
Beer Baron, when you do the UOA, make sure they test for all the elements Mo/Zn/Ca etc. TBN would be nice too.
Edited by Busky2k
Hmm I'll debate changing the filter ever 10,000. Personally I change it every 5000 kays as if I let it go to 10,000 I start to get noise from my lifters on startup due to them not getting oil fast enough. If that's not a indication of restriction nothing is.
I'm using the 4100 turbolight in my engine. I only leave it in for 5,000 kays myself. It is probably good for a fair bit more, but I like to make sure.
^^ Some filters use a poor quality anti-drain back valve to hold oil in the filter upon shutdown. I've seen countless Ryco ones do this after a while. Nissan OEM ones I have been good in this respect. Good filters use a silicone gasket (Eg Purolator PureOne) which lasts much longer. You can tell by if it has an orange valve at the bottom instead of black (ordinary nitrile rubber)
If the filter is clogged it goes into bypass so you wouldn't be able to tell if it was clogged or not without a pressure gauge plumbed in before and after the oil filter. And even then its difficult to tell.
I think this thread should be put in the maintenance section lol.
Thanks to the advice from Busky, i now use a pure one oil filter and castrol edge 0w 40 best change i did from the 10w 60 edge. Motor is running cooler and starts better,
And in the gearbox i run redline shock proof its well worth it.
Edited by subzeroR33
Well you got me there mate. Yes I do use a Ryco, guilty as charged. Interesting little piece of info there. I think I'd better invest in a genuine filter, always assumed they would be too expensive since everything else that the dealers sell is :happy:. Oil change will be due in a couple weeks. Will get 1 for sure now & try it out.
Yeah I have a personal vendetta against Ryco. I mean what kind of company charges well over $10 for a filter and can't even put a plastic seal over the end? Go wipe your finger on the base plate of a Ryco off the shelf and look at the crap thats on your finger. Lovely.
I believe Purolator's Premium Plus or PureOnes are far better than Ryco's offerings. Nissan are good aswell but the price varies. My local dealer wants $19 for one, where as I've heard others get em for $9! For $15, the Purolator PureOne is a better choice for the money.
Busky2k,
Head down to nissan they are around $8.98 or soemthing from memory, thats what my last one set me back.
I grabbed one to check it out, they do look very good quality and have a strange lip type seal.
However, I will be going back to the pureone filters.
$10 for an OEM? You must have a nice dealer. Main North Nissan want $19 for em lol. Then again the NVCS SR20 has a different thread to the RB so thus the part numbers are different. (and I believe most other post 1995 Nissans use the same filter)
And as everyone can see, the Nissan one has an orange ADBV, so its silicone and thus high quality. Good stuff. :D Not sure about that funny lip though, but it must work because the OEM one had one of the fastest times to get oil pressure after start up. Good ol Ryco was like 3 seconds lol.
Just called my local Nissan..
Village Nissan
425 Elizabeth Ave
Redcliffe, QLD, 4020
(07)3883 0900
While he was looking up the part number that CUBES posted a picture of *15208-H8911AU*, he was making small talk about what I do for work.
When I told him I worked for QPS he made a joke and said “Oh I better give you a discount so you don’t send your work mates here aye”
Anyway, he ended up giving me a discount anyway..
He can supply them for $7.70
I’ll head on over to see him this Saturday.
If there are other QLD’ers that would be interested in the future, or now I guess, I might have a chat to him and see if he can do this for this price all the time for the car club.
Busky2k,
The actual Nissan part number for R32, R33 (RB25DET, RB26DETT) should be AY100-NS007 (15208-H8911) but has been supersede by AY100-NS005 which is used by R34 so both can be used.
  • 5 weeks later...
good info.
I just used a Ryco and also thought it was kinda crap not having the seal on it. I did my FTO also and got a OEM one and it was a silicone one also...
damn...should have read this earlier...read up pplz!!
The oil filter sit shigher than the sum yeah?
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
    • HG's high flow is not "bolt on". The core is shorter, moves the comp cover rearwards in the engine bay. means you have to deal with the inlet plumbing a little bit. This is probably something to consider with every "bolt on" turbo anyway.
