Hi Guys,
Ive got a HKS T04E Turbo kit that im looking to sell.
They are all genuine HKS items. Not ebay knock offs.
The kit is to suit an RB25 or RB20.
The turbo is rated at 500hp and has just been rebuilt in Japan. Has not been installed on a car since rebuild. (i don't know too much about turbos so i may not have all the answers to your questions)
A.R - .56
Items included in Kit:
- HKS Cast-iron mid-mount manifold
- 45mm HKS wastegate
- 3" Dump pipe to Cat
- All oil line supplied
- Crossover pipe with BOV.
- Turbo elbow etc
Basically this is all you would need to bolt this turbo up to your car. Only thing you need to buy is some gaskets.
Asking Price: $1600 ONO
I am located in Sydney and would prefer pick up but intersate buyers welcome also.
Reason For sale: Only bought it for the sake of buying it (at a good price of course :D) and now i need the cash for a new clutch and 100k service :(
KIT HAS BEEN SOLD!
post-17623-1154001637.jpgpost-17623-1154001420.jpgpost-17623-1154001400.jpgpost-17623-1154001650.jpgpost-17623-1154001663.jpgpost-6973-1127038743.jpgpost-17623-1154001693.jpgpost-17623-1154001693.jpg[attachmen
=48664:attachment]post-17623-1154001741.jpgpost-17623-1154001753.jpg[att
chment=48667:attachment]
Edited by Stel
what A/R is the turbine housing,is it split pulse(pic if possible)?
Hi Guys,
A.R - .56
- Turbo elbow etc
Reason For sale: Only bought it for the sake of buying it (at a good price of course :whistling:) and now i need the cash for a new clutch and 100k service >_<
If you like to sell the wastegate only send me an e-mail and also tell me how much you are asking for.
Cheers,
EUGEN
PS Do you have any clue the spring in the wastegate for what pressure is?
Cheers,
EUGEN
Sorry mate, not willing to separate as yet. Will let you know though.
Thanks
Stel
1k
Sorry mate too low.
The HKS TO4E's should have HKS stamped on the exhaust housing, when I say stamped they are actually raised letters on the rear of the exhaust housing.
I was told that it was a HKS turbo. I don't think the old ones had HKS imprinted on them. Either way, Garrett make HKS turbos.
Sorry, but that aint a HKS turbo. Well not a genuine Kansai made one anyways. Ive had a T04E a few years back, and it didnt look like that. Sorry, but your details must be accurate according to what you are actually selling. Still looks like a good price for what you are selling.
When i got it i was told it was a genuine HKS so i assumed it is genuine.
im not tryna ruin your sale but i think it should be accurate, although hks buy their turbos from garret they put a shit load of research/money and mods into them. thats why there worth a bucket. so i dont think its right to say its hks just because garret make hks one. or it may be a older one. i dunnp thats just my opinion, eitherway good price, gl
its an old kit dude, ive seen quite a few of these olds HKS T04e kits now, even my own, and none have had HKS stamped on them.
Great upgrades, near on a perfect kit, awesome manifold design too.
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
