First problem i can see with that is the 90 degree silicone joiner from the turbo outlet...the radiating heat of the s/s manifold will weaken the back part of the joiner and it will eventually blow through :laugh:
Two race meets our one lasted, then i had to tig an ally 90 pipe on to replace it. Not having a go at your setup...it looks very nice. Just giving some warning. Being a street car, it might hold up alot longer, but my money is still on that it will go sometime. Maybe wrapping the manifold? Could help.
Very nice though :wub:
https://www.sau.com.au/forums/topic/127911-t04z/#findComment-2364487
First problem i can see with that is the 90 degree silicone joiner from the turbo outlet...the radiating heat of the s/s manifold will weaken the back part of the joiner and it will eventually blow through :teehee:
I would have to agree.
Also what exhaust manifold are you using?
https://www.sau.com.au/forums/topic/127911-t04z/#findComment-2364846
Same thing happened to mine on front straight at PI.
Very hard to figure out when it first happens coz you can see the crack until you start pulling things off
https://www.sau.com.au/forums/topic/127911-t04z/#findComment-2364886
I would also agree, based on personal expirience, i went through 2 90 degree bends :P
The heat from the exhaust housing just burned a hole through the silicone in a matter of weeks.
And fullboost @ 4500 :teehee:
I bet fullboost = 5psi
https://www.sau.com.au/forums/topic/127911-t04z/#findComment-2364894
IT WAS 12 PSI
https://www.sau.com.au/forums/topic/127911-t04z/#findComment-2364944
You will need to replace that 90 degre bend as i have had the same issues...
I have also found that the chinese manifold ok to around the 280-300rwkw area but anything more than that and they will crack and bend. The stainless is just not strong enough to hold anymore heat...
Also you want to insulate your down pipe from the back of the turbo with heat tape to aviod affecting you air conditioning pipe work...
Other than that, she looks great...
https://www.sau.com.au/forums/topic/127911-t04z/#findComment-2365502
The dump pipe is thermo wrapped....i tried to tell him to ceramic coat the manifold but he likes the bling factor. The manifold is no cheap "chinese knock-off" either its a well constructed local item with the runners extending right through the flange plate to the ports...it could have had a support tab welded to each runner for added strength though.
EDIT: many thanks to GCG who provided us with the "bolt on" water and oil feeds...."bolt on" yeah right!
Edited by DiRTgarage
https://www.sau.com.au/forums/topic/127911-t04z/#findComment-2365523
HAHAHAHA
GCG supplied me some 'bolt on' water and oil feeds....
The oil return is not really designed with a high mount in mind. As it touchs the manifold so im gonna have to run the turbo on a slight angle to make it all work with out burning anything... :whistling:
https://www.sau.com.au/forums/topic/127911-t04z/#findComment-2365615
Arhhh i could not see the rear... I just assumed it was not done...
PS. I am using a chinese manifold and she is working quite well but have been told not to push it too far...
Im only after 270 or 280rwkw anyways...
https://www.sau.com.au/forums/topic/127911-t04z/#findComment-2365620
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
