leaning more toward the boot lid rubber stoppers now. ive adjusted the latch to hold the lid higher and the rattle has quietened down but still auditable. ill pickup the stoppers tomorrow if i get out of the mechanics early enough. keeps u posted
  • Replies 45
SOLD!
Refer sig :D
Seriously though, you still have it? :no:
mate if only u were in melb. mate of mine has an import wreckers that deals with only skylines, silvias etc. he :D:( would have EVERYTHING ur after. almost garentee it! :(
new boot rubber stoppers fitted. the boot shuts a lot nicer but theres still a rattle... any other suggestions apart from gutting the whole arse end?
checked the 2 layers of the boot skin/reinforcement area? (common issue after putting in big stereos - need to silicon the 2 layers together so they dont rattle)
checked the licence plate mounts and plate itself?
hey mark, yeah i think I kept the tie down clamp thing. I'll have a look when I get home tonight, if i've got it it's your for $0.00 inc postage.
Thanks Richard, much appreciated. The existing one was butchered by a ham-fisted auto elec that had never seen a spacer.
stock speakers etc. dont wanna add too much weight to my car. ill check the skins and support stuff. i might go nuts with a tube of black silicone.
the whole plate assembly has been checked as i thought my new plates might have been vibrating. its not this...
thanks for the suggestions :)
ive been getting it ever since my coilovers have been installed, might be exhaust? had a guy in a wrx pull upnext to me doing 80kmh to tell me my exhaust was loose hahahah
Easy way to fix it? good stereo, the cars are getting old and unfortunately rattly, ive ironed out alot in my car but there are some deeep ones
question: where do you guys access in behind the rear 1/4 panels? do you go in through the boot? or can you access them by taking the interior trim off as well?
i gutted the inside of the boot and the interior eg:back seats, upper and lower trims (destroying my upper trims in the process...) you cant see diddley sqwat from the interior. most of the rear quarters is thru the boot.
new rubber stoppers are on the boot lid now and the latch has been adjusted. still got rattles...
ive had the exhaust checked before with 3 of us under the car on a hoist banging and shaking the crappa out of it. not a peep. ive thought maybe it could have something to do with the suspention. i still have the stock setup. anyone had anything wrong with their stock suspention? any rattles? still gotta hunt this nosie down.
Mr Ed32, is true about a good stereo but i do sometimes like to drive and listen to the RB26 in front of me. wicked note. which is why i hate distracting rattles!
anybody seen that computer lookin thing thats located inside the left rear quarter panel in front of the jack holder? WTF is it??
thats the module for the rear dimister? correct me if iam wrong >_<........and have u checked the left seat belt harness, if its bolted/seated down properly? got the same rattles in my car figured one of them just one more to find...sounds like the barrier from the boot to rear seats..but havent been too bothered to find out.
thats the module for the rear dimister? correct me if iam wrong :(........and have u checked the left seat belt harness, if its bolted/seated down properly? got the same rattles in my car figured one of them just one more to find...sounds like the barrier from the boot to rear seats..but havent been too bothered to find out.
i havnt tried the seatbelts yet. thanks for the suggestion. ive had the rear seats out and the panel between the boot and the cab out and the noise is still in there. it actually became louder. this is why i reckon its gotta be coming from the boot somewhere.
does anybody agree that its the module for the rear demister in the left hand rear quarter panel?
I have had this rattle since I bought my car and I know theres a bracket in the quarter panel holding the jack (in mine anyway).
Ive always thought it was the parcel shelf being loose and the speaker rattling against the frame....meh!
yea ive got that jack bracket in the rear panel. its securely fixed. ive driven around with the inside of the back of my car completely gutted including the parcel shelf. still hear this damn rattle! im leaning toward maybe the suspention setup?? its still the stock stuff so...
  • 5 months later...
sorry to reply such an old post , but i had the same problem on my r32gtst. Its driving me insane ! I sent my car to centreline performance to get them checked if its the suspension, but after a thorough check, it wasnt. I used to ask my mechanic to tighten the exhaust harness before and it was quieter. I asked a new mechanic recently to tighten it and they say it cant be tighten... so im unsure now ... Its really very annoying !!
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
