The latest Wheels gives the new Mazda 3 MPS such a glowing review, it has convinced me that I have to get one. Some quick quotes:
"From 80-120km/h in third, it can sprint faster than a Porsche 911 Carrera, HSV GTO, Aston Martin V8 Vantage, Falcon XR6 Turbo and an Impreza WRX"
"Exiting 35km/h corners (in third gear, mind you), the MPS will lay two extrovert black lines straight up the road, and yet does so with surprisingly little torque steer"
"At 60km/h with three people on board, the MPS was breaking into wheelspin in fourth gear as max boost arrived"
Sounds like an absolute riot to me! Perhaps not as sophisticated as the delicate balance between slip angle and wheel spin during a perfectly executed four-wheel drift as you might get in a more rounded rear-drive car (say, a skyline), but hey, that's not really what you buy a 190kw front wheel drive hatch back for is it?
https://www.sau.com.au/forums/topic/128073-mazda-3-mps/
Would be an awesome little daily driver, very cool for what it is for sure.
Weird. It's as fast as an RX8, obviously not around a track, but in a straight line. From roll on it sounds very impressive. Plenty of mid range meat by the sounds of it.
https://www.sau.com.au/forums/topic/128073-mazda-3-mps/#findComment-2367387
Mazda3 MPS would have too much torque steer and this Drive article seems to think so too:
http://drive.com.au/Editorial/ArticleDetai...articleID=18339
From the article:
The engine has too much power and torque for a front-drive layout; it then uses electronics in a vain, inept attempt to cover up the problem. We were happy to park it.
https://www.sau.com.au/forums/topic/128073-mazda-3-mps/#findComment-2367469
From the article:
that's the most uneducated and idiotic thing ive heard
https://www.sau.com.au/forums/topic/128073-mazda-3-mps/#findComment-2367504
My dad & I took it out for a test drive at the Penrith Mazda along Mulgoa road
The salesman didn't let us drive it without him & made sure we behaved ourselves, although we did take it on the m4 :nyaanyaa: .
acceleration is very linear & I didn't notice any boost spiking (turbo cars these days :D ) although honestly we didn't have much of a chance to put it through it's paces.
same engine as the mps mazda6
it's still a fwd but it's got some Dynamic Stability Control something or other
cons: I hate the hatch, would've been much nicer as a sedan imo
Also test drove the xr5 focus, not bad although I wouldn't pay 40k+ for it
rather spend the extra dough for an mps3
https://www.sau.com.au/forums/topic/128073-mazda-3-mps/#findComment-2367523
thats why people have done engine swaps with the rx8 and put the rx7 series 6+ engines in it - 13b i think it is.
It's the right car for Mazda to make now, bring the rotary to the masses and make money. But for me it is too slow. The FD was a failure in the sense that it was not profitable for Mazda in the US, their biggest market. The RX8 is fixing that and fingers crossed we will see a car as good as the FD again (except maybe a little less tempremental!).
https://www.sau.com.au/forums/topic/128073-mazda-3-mps/#findComment-2367760
its 4wd isnt it?
No, it's front wheel drive.
Less tempremental reliability then yes. :D
But it's the perfect car when it comes to the mixture of chassis, handling bits and performance.
https://www.sau.com.au/forums/topic/128073-mazda-3-mps/#findComment-2367764
like i said on another thread, imagine the potential in this little thing has
if it had around 250kw it would be an absolute death trap!!
how heavy is it?
Heavy for a hatch of 10 years ago.
Normal for a hatch released since 2000.
Around 1400kg.
https://www.sau.com.au/forums/topic/128073-mazda-3-mps/#findComment-2369011
    • Finally have an update on this  Rack came in this week so I did a test fit. You do need the S chassis bushings since the rack is 5mm thinner than the R33 rack. The main issue I foresaw and ran into was one of the hardlines not lining up properly with there it's meant to on the rack. After some gentle coercing and bending very slightly, I managed to get it to fit without any kinks and keeping the hardline pretty much in all of the factory mounting positions. I did have to unbolt all of the soft mounts to move the line around so I could snake it out and bend it safely but it looks good to me for now. I'll update when the rack is fully bolted in and functioning.
    • I hear this thread needs an update following its adventures last Wednesday!
    • What are you thinking makes a sequential shit to drive on the street? About the ONLY thing I can think of, is if you're wanting to be able to roll up to lights in third or second and pop it straight into neutral, or you want to come down two or three gears, say out of 5th and back to second, but they shift quick enough it doesn't really matter
    • I'm not a drag racing guy, but that was a good watch. Didn't Ibrahim's car have some cooch! But the big question is....WTF is with so many of them running without seatbelts!
    • Sequential Is fine to drive on the street
