from my knowledge of the rule its ok as the pods would be considered 1 intake mod. if you were to change the intercooler that would count as two intake modifications. best to ask vic roads as a lot of their rules are full of grey areas and exceptions
when i spoke to the EPA last about aftermarket front mounts, they said as long as you can prove it is within stock dimesions then its fine. But i couldnt be assed taking off the front bar to measure up the cooler and just used a stock air box instead!
Im sure this has been asked before, but would i get away with a enclosed POD? Legally? Its still a modification but.. not off the shelf, and its roadworthy so.. any ideas?
the pod doesnt have to be enclosed as far as i'm aware (although its useless if exposed to the engine bay anyway)....
As long as its secured to the car, and is the only intake mod, its legal
Someone from EPA mentioned if you have a Pod Filter it has to be the Dry kind not the Oil Soaked ones. Anyone confirm this?
The Reason why I ask is because everytime I ring up I get a different response.
Edited by beefy
what if you have a pod in and enclosed box that you cannot see, and a cooler, what can be done ?
When i called the EPA regarding this i was told only an exposed pod OR a cooler. Unless the car comes with a factory intercooler then you can have a pod as well.
Oil Soaked pods are illegal, the dry kind are fine.
Having a pod, whether it be enclosed or not and a Intercooler thats not stock or is relocated is illegal.
A pod with a stock cooler is legal.
A FMIC and stock airbox is legal.
You could get alway with an enclosed pod if the box looked factory, but its still illegal.
Cheers
Edited by stealth01
  • 3 weeks later...
If that's the case, I need some help. I have actually 'misplaced' my stock air box in my garage (it happens). Can't find it anywhere now. And I have ordered a new FMIC recently. Since I still want my mods to be legal, I want to replace my pod with a stock air box again. Anyone out there willing to sell me their stock air box. I have a R32 GTS-T and I live in the outer east (Knox area).
EPA Mod Rules Extract February 2006
© Intercoolers that are larger than standard or have a different mounting location or are added where none were originally fitted, are permitted only if no other changes to the intake system have been made. In other words, you may have a pod filter or modified/added intercooler, but not both.
Any sensors integral to the original intercooler or intake system must be retrofitted and be in the correct location. Note: aftermarket turbocharging kits that include intercoolers that have been type tested (ADR certified) for the model vehicle are permitted. Documentary proof must be retained to substantiate this.
(b) Dry element pod type air cleaners are permitted on EFI vehicles. Oiled, oil-soaked or fluid-treated elements are not permitted. Any sensors integral to the original system must be retrofitted to the same approximate location.
Variable turbocharger boost valves (‘boost controllers’) or other means of altering boost levels are not permitted unless part of an original manufacturer’s fitment. ‘Blow off’ (‘pop off’) valves must be plumbed back into the system. Atmospheric venting is not permitted. External wastegates are not permitted.
Non-original electronic chips or computers, whether fitted as a direct replacement or in a ‘piggy-back’ configuration, are not permitted to be used in an engine management system unless it can be demonstrated that their installation and use allows the vehicle to meet the appropriate ADR. They must also be sealed or otherwise constructed so as not to be reprogrammable.
So who here can say they do not breah any of the above rules?
With my new setup, me.
Either way, its not a question of who can pass or not.
The rules are there, they are readily accessible.
So next thread about "can i have a pod" gets locked :(
hehehe...i wold have thought most ppl would have aftermarket ECUs and boost controllers... Pods and ICs are visible and hence gain the majority of the attention. Just don't drive like a hoon or be on P plates...The insurance companies don't seem to care much, having made a massive claim with most of these known on their books they still payed out no quetsions asked. I would have thought they would go to town on this stuff, maybe they do sometimes and I was just lucky.
Has anyone experience problems with their insurance companies from their mods?
    • Please use a modern ECU. PowerFC with the Nintendo Gameboy controller is horrible. It's not 2005 anymore.
    • The car/ECU will have all the sensor that it needs and expect to have. I think i do not have to explain to you how the Link is way better specialy if you have swapped engine   I just do not want to deal with any "problems" cuz i have only Nistune which i learned is not that great and in my case cant even deal with that speed problem (Link can) And of course it will be way more easier to tune and diagnose and safe. And for the ECU/speed problem...i dont know.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
