Not sure if its been posted before (the video looks old even though it was only posted on YouTube recently). Search turned up nothing.
Jeremy Clarkson of Top Gear fame test driving a 1000hp JUN R33 GT-R.
http://www.youtube.com/watch?v=bdzTXJLxjaY...arch=top%20gear
https://www.sau.com.au/forums/topic/128363-clarkson-drives-a-jun-r33/
In the episode last night he just got delivery of his new Ford GT40 or whatever? I know their old episodes that are on know though.
The funny thing was he couldn't start it as his immobiliser wouldn't unimmobilise the engine...
i'll d/l and watch it at work tomorrow - Im on crappy dial up :)
Does anyone have a link to the video where it was the wrx vs evo lancer and then the R34 GTR came in and Jerermy Clarkson was thrashing it?
years ago.....but cant remember!
On Clarkson Unleashed the chick from 5th Gear Vicki Butler-Henderson drives a Gun Metal Grey 600hp R32 GTR
Clarkson also drives a 32 GTR on the Meet the Neighbours Japan episode opr was it Car years eitherway it's on of the very old videos.. he even talks about drifting and there are Japanese dudes in old skool pastel shirts etc.
I'm just hanging out for Top Gear to eventually test the new GTR around the Top Gear test track.
Edited by CONRAD
"oh look im on a drag strip!" ahahaha dude i love the topgear show.
anyone seen the one wher they invent the first convertable people mover? i laughed so hard in that...
picture a tarago van with no roof.
oh taht red thing.... the renault espace?
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
