For an amateur who likes to look after their paint I really recommend the ZAINO all in one stuff.
Have done a couple of cars and very easy to use.
My process is usually
Wash
Clay
Wash
Zaino Z-AIO
Zaino Z-CS usually 2 layers
Zaino Z-8
This is the only pic i have atm, and this is about 2 months after it was done. Zaino lasts for ever :-)
Ok long time since I have posted here so have changed my products a bit. I now use Menzerna products for the prep work wouldnt use any other. For Sealant I am using Zaino Z2 and for Wax I now use Collinite 915 lasts for 6 months :D . As a quick detailer I am using Aqua Wax, good Stuff. There are several othe products that I use but I will keep it to the main ones for now. Some pics of my Commy and the Coupe I use pics of the Dunnydore because it is Black and shows the results better.
the gloss you achieve is just insane mate, but i thought you were using a Dodo wax?
NISMO: nice products, Zaino to make "some" great products. Is your black metallic or jet black?
IMO switch the Z-CS out for Z2pro, and maintain with Z8
Yeah had the Dodo, it is a great Wax, then read a test on DW who tested some of the best/dearest waxes and the Colli 915 come up pretty good in the test. I gave it a go were the Dodo was $80 and the Colli has cost me $36 from USA, so damn cheap with both Waxes having an awsome depth and gloss the Durability of 6 months the Colli won.
Edited by R31Heaven
Hey mate, It's a jet black. No metallic flakes through it.
I went with the Z-CS simply for it's ease of use. I'm a bit of an amatuer and it's the first time I went with a higher end detailing product. I kinda shyed away from the more "pro" Zaino stuff becuase of the need to mix it before use. But have have seen Z2 layered several times with Z8 on top and it'looks great.
The other thing with Z-CS was it's all purpose useage. I used it on the mags, windows, headlights and all dirt/dust just slipped right off.
With the Z2, would you still use Z-AIO and would it be before or after?
Very happy with Zaino, but I've sold that car and now have a white GTR so unfortunately you don't get that satisfied detailed feel as much on white.
Everyone must remember that you will get varying results with any Wax or sealant if the Prep work is not done properley, using a relevant Polish first to remove imperfections is the most important part to get a good finish. The Wax will only enhance what is under it.
Yep, 100% agree. The picture of the blackk V35 I posted above, involved 1 1/2 days of correcting the paint before the first coat of anything was applied.
1 - Dawn dish soap wash
2 - MF dry
3 - Spot rubbing compound
4 - Fine Grade Clay, then remove resedue with MF + Meguires 2.0 Quick Detailer
5 - 3M Swirl Remover, then remove resedue again
6 - 3M micro polish with light cut pad, remove resedue again
7 - Mothers Stage 3 Hand Polish/ Glaze, remove excess
8 - Meguires NXT Paste Wax 2.0
Edited by Koshi
is there any way to remove a deep key scratch?
it looks pretty deep.
ill try scratchX but i doubt that will do anything
will i be able to use touch up paint on it or is the only way to get it fixed is to respray the whole door?
key length is around 40cm long.. punk ass bastards
  • 4 weeks later...
this is what i do
wash car using autoglym carwash.
microfibre dry
meguairs claybar
wash and dry again
polish with autoglym polish...the one for darker cars.
wax with meguairs deep crystal carnuaba wax.
this is my mates car we did...this is pics taken after the polish...no wax yet (ran out of time)
i was pretty happy with the result...but i wana get it better so i have been looking onlne for better products and i have a few questions.
firstly - what is the difference between a pre wax cleaner and a polish - are they the same thing? some online shops mention pre wax cleaner and i figure they are similar.
second - whats the go with layering waxes - especially ahrd and soft?
third - is their a kind of sealant (wax etc) that is bit longer lasting? all the carnauba waxes seem to say re-apply every 2-3 months and re polish every 6...is this to do with the synthetic vs carnauba???
im doing my car today...so i will post up pics for you all to see :D
BTW - sorry for the pic of the car used...as stated it is a mates :blink:
Edited by Gus-
If you're looking for longer lasting, alot of people recommend (including me :-)) Zaino.
Most applications are expected to last 6-9 months. I've used it on a couple of cars but unfortunately none that I've had for over 6 months. But it was fine through those 6 months.
And as you've said, it's a synthetic product not a carnauba.
  • 1 month later...
Most Waxs and sealants give you a better shine as you layer them, as a general concensus 3 layers will give you the best result any more does not give you any better result.
Just a couple
Zaino Z2(sealant) 6 months
Collinite 915 (Wax) 6 Months
Duragloss Total Performance Polish #105 (sealant)6months
Swissvax Concours (Wax) 4 months
Megs NXT (sealant/Wax) 2 months
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
