Hi, could someone check this VIN for me? My Fast cannot pull it up... I'm about to buy this car. Thx alot
This is for Vspec2Nur (The seller Claim it to be)...
Chassis: BNR34-400956
Vin #: GGJPRWYR34ZZAAGZ80
Doesnt come up on mine as well, model code indicates it is a Vspec (not sure what version), made in Feb 2001. I thought the NUR version was 2002 ? More qu's need to be asked I suspect.
Mine also doesnt come up on 2008 Jap FAST as well, as i suspect some are deleted from Nissan's database when they are exported.
How about this one
BNR34-403508
again nothing, sorry :D
however i did find out that with 34 GTR's my last recorded vin is
BNR34 - 402137 and anything bigger than that number is not on there.
that vin shows manufacture in July 2001 so i'm guessing the version i have has not been updated since...
Hey..
Not sure if you need any more details but Could you please do this one for me.
rb25 163672a
Cheers
Not sure what those numbers are, check your vin number and it should read something like 6U9000ECR33012345, what i need to do check it is this part of the vin 6U9000ECR33012345
check it out and let me know what it is, ill check it out asap ;)
Use this link to decode your model code
http://www.users.on.net/~goofyhsk/info/chassis_plate.html
It will help you decode everything except the last 4 letters, L, M, Z, G. The following is what i wrote back on page 39 of this thread about 10 posts down if you want to see my entire post.
I have been doing a lot of searching around on the forums for the answer to what the last letters mean on the model codes for the early model r32 GTR's (L,M,Z and G).
cameronbnr32 and garrysandy the only info i could find for you guys (and any one else wondering) was a post from funkymonkey back in 2004.
From what i read the letters L and M, which occupy Positions 8 + 9 in the model code, are known as VS Sign (VS Options)...
L means it has Projector Headlights
M means it has both climate comtrol + upgraded stereo
Letters Z and G occupy Positions 10 + 11 in the model code and are known as Pack Sign (Package Extras Sign)...
Z Im still not sure what it means but some guys believe it might be to do with the interior trim. RellikZephyr Thought Z = Black Interior Trim.
Cant be confirmed unless funkymonkey or someone else knows for sure what it means.
G from what i found means ABS and a Viscous LSD
Hope that helps a lil.
Was this ever expanded upon? My car has one of those odd model codes.
KBNR32RXFSLMZG
Strangely this gives a build date of 6/90 rather than the FAST 10/89 for my chassis BNR32002505:
http://fteqw.com/moodles/model-decoder.php...amp;chassis_no=
This doesn't give all the answers either. So weird. :)
KBNR32RXFSLMZG
As far as i know there is no date information in the Model Code, so 10/89 it is.
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
    • yeah I was shocked when I checked my spare OEM on and as below that's how they come from Nissan. (side interesting note new NEO gearbox and replacement park lack the brass bush on the tips and its just all alloy) unsure about damage to the box currently back at 1110 to be pulled down/inspected and selector fork replaced as he built it previously and given the never before seen failure on his billet forks he is replacing it under warranty. He said he has used always OEM the keyway tab without issue for years so it could be an unlucky coincidence. I did talk to him about the sharp corners and stress concentration too. Re: hard shifts i got 7+ years out of the OEM one and the fork itself failed not the keyway. so could be bad luck as I said or an age thing + heat cycles in box and during fabrication of billet?
