Sorry guys i have been away on holidays for a while.....
ok, i did a bit more of a search, and came up with this.
on the fast screen shot, where the model number is, if u look at the 6th character along it says Q.
Q = non Vspec
W= V spec
is this correct? if so the one im looking at isnt a v spec.
Yeh mate that is correct. Also in fast when its a vspec the forth line where it says GTR will have GTR/vspec or GTR/V.
Hi people,
Im looking at going to Melb this sat to buy the following. Can someone do a VIN check and let me know what comes up.
1996 R33 GTR V-Spec
Model no: ggjprqfr33
VIN: BCNR33002497
Engine No: RB26050285a
Colour code ano K
Thanks
Cant get yours to work with either the vin or the model code. Might want to recheck it all to make sure thats right.
yeah could someone fast mine cheers
hnr32-001250
model:krnr32rgfslmcb
Here is yours.
Hi,
Me again, maybe I need to get my arse on installing the software (what file do I need to use for Skylines both chassis no and parts)!
I'd like to find out anything special about this chassis no.
BNR32001945 - Supposedly '89 In black.
Cheers
Grant
For all japanese imports the files youneed for fast are A1, A2, A3, B1, B2
It comes up as a black 89 gtr. Here is your fast
6u9000bnr32303621 32 GTR DUDE
Here is your fast too
To decode your model codes you can use this website
http://www.users.on.net/~goofyhsk/info/chassis_plate.html
Hi,
Could somebody please FAST "6U9000BNR32221872". Looking to buy this car within the next few days, very much appreciate some help :angry:
Thanks again,
Sean
Sept '92 GT-R, Colour Code 326, Model KBNR32RXFSAA
buying an R34 In a few Weeks and need the following VIN Fasted.
6U90000ER34007614
Cheers.
June '98 R34 25GT 2-door, Auto, Colour code KV2, Model GGKAREAR34EDA-JF--
I'm afraid I can't translate the special option codes @ characters 15 & 16.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
