July 1996
R33 GTR
Champion Blue
But it doesn't actually tell me limited edition or special model so not sure if R33 GTR LM.
Anyone else can confirm this?
Champion blue came only on LM GTR's
If you want more info pm me or look here at the bottom of the page
http://www.skylinesaustralia.com/forums/Ra....html&st=60
anyone able to fast this? BNR32007526
suspect this isn't the car im after.
Model : KBNR32RXFSLMZG
Prod : 90/04
Color : 732 - Black Pearl Metallic
Int Color : ??? came up blank ???
Model : 2k
Engine : RB26DTT ?Typo in prog i thinketh
Drive : Man Trans , HI.4WD
Type : GT-R
Hope this helps
Edited by BundyBear
hmmm
double checked it..
on the metal plate it has
E-ECR33
ECR33-132249
engine RB25DET
then some jap which i cant read.
defari
Mine came up invalid to. (using V3.5)
Whats the model (Under VIN 18 chars, Some "-"'s) VIN's can be "Side steped and verified" with FAST
I suspect the 2249 may be the prob . minez close at 130310, Maybe they don't go that high??
Edited by BundyBear
hmmm
double checked it..
E-ECR33
ECR33-132249
engine RB25DET
I get this:
maybe you can grab a shot of the VIN plate and post it...
Hi guys,
Can you please do me a favour and put this VIN through fast for me?
BNR34006541
Thanks in advance :(
ECHO
ECHO
ECHO
ECHO
ECHO
ECHO
ECHO
Anyone still around!? LOL!
March 2000
R34 GTR Vspec
Bayside Blue
