Hi all, i'm new to this forum and have put a deposit on a R34 GT-T today!.
Would someone be kind enough to check this VIN for me? (I probably should have checked before paying the deposit).
Thanks in advance for your help!
VIN: ER34012606
fast request pls:
6U9000BNR32009882
thanks
Urgent FAST request please my good man :down:
BNR34005113
Ozzie # is 6U9000BNR34005113
is V-tech is good.
Cheers
Thank you very much BundyBear.
Would anyone be able to help out on the following:
* Colour: QM1 White
* 2K not sure (either 2k or 4s) most 2k
* MT.F5 5speed Manual
* HI.2WD Hicas(4 wheel steer thingy) & rear wheel drive
Thanks guys
So basicaly you shoud have a white 34GT-T with hicas.
If you 'decode' your model number (the GGKB...) it will tell you what options were fitted @ factory, do a search on SAU as memory tells me there are at least 2 threads covering decoding.
Chers bb
Edited by BundyBear
Chers bb
Thanks bb - so far so good... now i'm going to look up the model number :)
thanks Dark26, for some reason my mate's copy of FAST wouldn't accept the VIN, we'd been wondering whether it was an optioned up GTS or GTS-X lol
Hmm maybe its a different version? I'm not sure, anyways, no problem!
Hi,
was hoping someone could help me out with an ID on my GTR.
VIN is BNR32-002002 Model is KBNR32RXFSLMZG
I know the car was built in 1989, but i am unsure what the last four letters on the model code mean. (LMZG)
Hopefully someone can give me a heads up!
Thanks!
Edited by Outrun
Hi,
Thanks!
BNR32-002002
I did a search of this thread and according to pg 39;
L = Projector Headlights
M = Climate control + upgraded stereo
Z = Might be black interior trim
G = ABS and viscous LSD
Hopefully thats right.
hey i just bought a nissan stagea, can you please check it for me
WGNC34 - 138165
Thanks
WGNC34 - 138165
BNR32-002002
Thanks Heaps !
WGNC34 - 138165
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
