Some one please FAST this for me?
6U9000ECR33108783
Just wanna know the options and stuff that it has.
Cheers,
Love you all.
Vish.
here you go. i don't read japanese so can't help you with most of those options. easy to see what a couple are though.
i was just hoping someone could fast my chassis # for me..
the vin/chassis is 6u900wgnc34104215
im not sure if the wgn is needed for fast if not
chassis # c34104215
thanks in advance
You just drop the 6U900 off the front of the vin and thats the Japanese vin that you run through fast.
here is a screen shot of you vin code search with the blue Autech window that pops up on a vin search. :D
here is a screen shot of you vin code search with the blue Autech window that pops up on a vin search. :cool:
thanks for that mate seeing the blue autech window made my day..... :ermm:
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
    • Yes then it will turn on but I want the car features to work
    • My thought is if you were just moving it forward and the upstream geometry remained the same, then no difference at all. But because the current one has the filter direct into the AFM inlet, you effectively have the best chance of a completely symmetric air flow profile upstream, and in, the AFM, whilst the aftermarket inlet thingo has a (small, to be sure) bend between the filter and the AFM. That would bias the flow to the outside of the bend (downstream of the bend) which might well reduce the size of the signal seen by the AFM, for the same total flow rate. Having said that: If you're proposing to make your inlet look like a hybrid of your existing one and the aftermarket one, such that there is no bend where the filter is clamped on... then I say it will be just fine. If there is going to be such a bend, then, if you can align the insertion of the AFM blade such that it is at right angles to the plane of the bend, then there is a better than even chance that the centreline velocity where the blade is will remain more or less the same, and the velocity will just be a little faster to the outside of that, and just a little slower to the inside. **This is not professional investment advice and you should consult a suitably qualified ouija board, tea leaves or the intestines of a goat for more accurate prognostication.
    • Hi Tao, Thanks for your reply.  It's been a while and I managed to get the valve stem seals replaced with the head on the car.  Unfortunately this didn't solve my issue, the car still smokes a lot after idling (to be honest during idle you can see a bit of blue smoke from the exhaust), same after deceleration. I will try disconnecting the valve cover breathers, do I leave the PCV valve in? By engine oil drain pipe, do you mean the turbo oil drain?
    • What about if you just give it direct 12v and earth?
