yes...
VS2 Nur
what is your VIN?
i cant see pictures at work but i work at NISSAN and my FAST is updated by the month .....
Why i have a copy right next to me on DISC :)
My gratitude for 6U9000BNR34402974
I have emailed a file to myself at home so tonight i should be able to upload onto something like photobucket. There are to many restrictions on the work computer to upload it at the moment.
thanks randy, just a quick one though, what does the 2k mean? and production month/year?(9008) september in the 8th year of whatever emperor?
thanks again, legend.
Cheers!
2K should be two door, and the production is in year/month ... 1990/08 =-]
Care to share? =-]
Why would you want a new copy of FAST for to look up things like JAP 2012 GTR's????? haha
I would be able only via USB. Nissan only lend the disc out for 1 day a month when you do the monthly update. I can easily get the files onto usb but.
Northern beaches is pretty close to me ;)
Edited by central coast person
right you are!
always worth checking out how they started life though ;)
what does black interior refer too? dont all the R33's come with the same standard interior?
Black R33 GTS25t (M-spec), manual, HICAS, black interior, September 1993 build.
Much like the one in your avatar!
right you are!
k = black interior
Yes all r33's are 'k' but other Nissans may not have black (k) interior. Like a TIDA or whatever dosnt have black interior, haha.
hehe... well.. it would be nice to look up post-2001 cars for the guys here. ;o)
I'm happy to obtain it any way you prefer, but i'm not sure how close you would call the Northern Beaches? Takes me an hour to get up to the Central Coast.
Let me know in any case, i'll try and make it easy =-]
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
