Interesting how the VIN is greened out on the green plate. I think it's a bit alarming that a wreckers complied the car. I think they may have made the number up. Have you got the car?
<a class=post-3573-0-27931600-1326308742_thumb.png' alt='post-3573-0-27931600-1326308742_thumb.png'>
And when I do that, it says it's an invalid date for the model.. which is right. My 96 S2 is 114098. Much higher.
Oh... I see in the post they say it's a 94, and it looks like a series 1... but the compliance plate says 1996. lol.
My FAST is not working
Looking to buy a V35
Can someone please FAST me the following?
Chassis: CPV35-503915
Model: GLJARVNV35EDA--E--
Chassis: CPV35-601550
Model: GLJARVNV35EDA--C--
Thanks
I now have a copy of Nissan FAST 2010 up to April 2010, so I can look up V35, V36, R35 etc if anyone else needs it.
Some cars are complied as wrong years to get around certain things. Also compliance VIN is pre Sevs and is therefore a randomly generated one not a u9000 etc one.
Have car and VIN is same as blue plate shown in that thread.
Edited by Miguelone
