I would appreciate it, if someone could do mine:
BNR32 - 301782
Hey guys! Newbie here :P
Where can I get my vin/model no decoded?
Cheers :)
Post it in here and myself or one of the other guys will post it up when we have a chance.
You can use an image host such as tinypic, photobucket, imageshack etc then grab the direct link to the image, click the little picture of a tree just over the post box and copy the link into there.
Too complicated! loll I'll try explain what my problem is...
If my JAP plates say my car is a 1994 build why does it
say the following on my Aus Approval plate?
Approval No. 14134 Category MA
Nissan AAX Skyline R33 2DR *1993*
02/02 VIN 6U90000ER33014230
AAX PTY LTD
79956
*1993*
I remember reading somewhere that under the old Low Volume scheme there was only a certain number of import plates allowable for a specified model in a specified year so to get around that they'd do the compliance paperwork as a different year. My old parts car was a 1994 model but it was complied as 1996.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
