Will need the Original VIN number off the Blue build plate/firewall mate. Pre SEVS copliance VINS like that can't be run through FAST. :)
Weird that the build plate is in Green... anyways i got the VIN here, hope it works
BNR34-003490
Hi there,
Could anyone please run an urgent search on VIN6U9000BNR34000553 as I am looking to purchase?
The model number shown on the Chassis Plate is GGJPRVYR34ZZAABJED.
Just want to check whether it is a standard GTR or V Spec and also what factory options were included if possible.
Thanks
Hi there,
Please help check out the info on this one, 6U9000BNR34401851
Thanks in advance! =]
Big Rear Brakes
Super Fine Hard Coating
Advanced Aero System
Privacy Glass
Rear Fog Lamps
Multi Display Meter
Rear Wiper
BNR32001477 please
Hey could someone please check this for me:
bnr34401380
Thanks in advance
Spec Codes:
Big Rear Brakes
Privacy Glass
Rear Fog Lamps
Multi Display Meter
Rear Wiper
Hey guys, can someone FAST thia one for me please?
6U900WGNC34135673
Thankyou
can someone tell me if my gtr is a vspec and the options bcnr021695
I think you're missing a few numbers, please check again.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
    • I suppose it was relatively stock too, the JZ motor handle most mods thrown at them without even breaking a sweat
