Another quick question, what body colour is TV2?
the Gtr im looking at is an r34 gtr vspec but the body colour is white!
TV2 = Bayside Blue
QM1 = White
QX1 = White Pearl
What colour is the engine bay?
Sorry for another question, I see alot are saying they have a blue vin plate, the one im looking at has a green one? Why would this be?
AUS Compliance Plate.
Does the R34 GTR, you are looking at, have the Blue Plate as well?
Couldnt see a blue plate anywhere, took a photo of the green plate on the firewall! Have requested the chassis number, the green plate says the car was manufactured by STIK performance cars! Or am I lookiny at the wrong plate?
Engine bay and car appear to be all factory pearl white, obviously the engine bay doesnt look to be pearl but definitely doesnt look resprayed!
STIK Performance Cars is a used car dealer from what I have read...
http://www.skylinesaustralia.com/forums/topic/334886-missing-vin-plates-and-compliance-plates/
I'd say it's a white car but the green plate has a typo / error with the Colour Code.
Get the Chassis number and run it, with your transport department ie. VIC Roads, or which ever state you are from.
Yeah I assumed it was an error, As the car looks like it has just rolled out of the factory in that colour, no signs of any respray work!
Ill run the Chassis number through QLD Transport and see if they can give me any more info on the car! I assume I can just do a VIN check to check that.
Yeah, sounds good!
Do that and see how you go.
Does the Vin stamped on the firewall match the Vin on the compliance plate? If it does and it's coming up as a bayside blue car I'd say it's likely a rebirth. Especially if it's missing the blue plate.
Will check out what the details are when I get it checked over mechanically and compression tested! The car is an excellent example and the owner is the second owner in aus since the first obviously purchased from STIK used cars.
I couldn't see a Vin stamped on the firewall anywhere, just took a pic of this plate so I could do a VIN Check.
Ill see if I can get him to find the stamped numbers and letters on the chassis anywhere!
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
