hi all,
just after some help on what turbos people here have choosen to upgrade their RB20.
i know people say upgrade to the RB25 turbo but i was wanting more.
i was after something which spools quickly as i am after some quick...
would something like a GT2530/35 be any good???
also what is the standard RB20 turbo?
any info would be sweet.
cheers
https://www.sau.com.au/forums/topic/128947-rb20-turbo-upgrade/
Different people have different ideas about how radical they want to go....
An HKS 2530 will spool about the same as the original turbo, but you can run much higher boost because it does not have the problem of the fragile ceramic turbine wheel. The 2530 is also more efficient at higher pressure ratios, and has higher maximum airflow than the original turbo.
The problem is, these 2530 turbos are now getting very old and HKS don't make them anymore. A secondhand one may be worn out or stuffed.
But HKS are about to bring out a brand new replacement for the 2530 which is 2006 state of the art technology, called the GT-ZZ. The dealers do not have them yet, but maybe in a month or two, who knows ???
Latest technology with turbos, is like latest technology with computers, always better and advancing very rapidly as time goes on.
Not always....
The old design turbos all had a much narrower flow range, so turbo matching was a lot more critical, a little bit too big, and it WOULD be a lag monster. Too small and there would be no top end airflow.
What the latest technology turbos have is a vastly wider flow range, as well as less inertia and a higher overall efficiency.
So you can now fit a larger turbo and get more airflow without losing anything in response or boost threshold. Or you can downsize slightly and get a massive improvement in response and mid range, without losing anything up top. It may not have much extra horsepower to brag about, but it will make a much faster and easier to drive road car.
Don't just think about turbo size, think also about flow range. The latest in turbo technology is always going to beat the older turbo designs in every way.
so if the RB20DET is laggy, what causes the lag?
is it because the throttle body is right in the middle of the rocker cover?
so with a front mount is has a long pipe from the cooler to the throttle body?
no.
2L capacity = not much exhast gas being produced to spool the turbo at low rpm. this means the turbo comes on slowly
larger capacity engines produce more exhaust gas, thus find it easier to spin the exhaust wheel and can generate boost quicker...
TB has nothing to do with it, and length of cooler pipes makes sweet f*** all difference also.
mmm.. you will find cooler piping does make a noticeable difference.
A top mount cooler running f**k all piping will seem quiet more responsive and less laggy, where as a large say 3' piping onto a fmic will obviously have more lag as the air has to travel further to get into the motor!
It wont be huge but its noticable!
In regards to the turbo you should get sh*t all lag with a HKS 25/10!
A 25/30 will be more similar to a stock turbo and can flow up to 280rwhp (with supporting mods),
Anything bigger and you really start to notice lag, which wen you run around with a low compression 2l motor isnt the best lol
Edited by jazza08
so you have noticed this yourself, on your own car?
or are you writing from keyboard experience?
i went from the stock cooler to a larger FMIC with 2.75" piping and noticed no difference in lag. i think and change would be minimal and not noticable...
from my experience, its right in theory but doesn't really translate in the real world...
I noticed a bit of lag since i put my cooler on yesterday, but more top end...
and VL turbo flutter... cho cho cho cho cho :thumbsup: love it
Im thinking turbo upgrade too. My theory is best bang for buck, with 25% more flow, better top end and more boost. r33 turbo for $350 is best bang for buck in my eyes. spending over a grand on a turbo for a low teens car dosent appeal to me very much.....
i had stok cooler came on boost mad 2nd gear peelin on boost
went to 3inch mandrel from exhaust technology with hybrid cooler f*k me lag monster but yeh top pulls way harder !
mates cefiro same so yes lag is big issue with cooler pipes
ok then...
if i got a standard R33 turbo hi-flowed etc could i get it turned into a ball bearing turbo?
or will it remain standard bush bearing/roller bearing?
and would the internal wheel be changed to a steel wheel or stay ceramic?
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
