The one thing that no one has seemed to mention throughout this thread is "why the hell would your tuner take your care to such extremes when he (or she) knows it is dangerous to the engine at that point"
330rwkw or hp; from a stock set of injectors... I'm no expert but I'm going to ASSUME that at this power your injectors would be at 99.99% duty cycle. The tuner would be able to see this if they were doing their job correctly; shouldn't they stop and warn you that your car could blow up?
When I got my car tuned (has pretty much everything except for injectors as well... the tuner stopped at the first instance and he warned that if he kept going for more power; I ran the risk of blowing up my motor. Even when I asked him if there were any other ways of doing it; he insisted that the session ended and I went away and got injectors.
I wonder who tuned this car and why they would keep pushing it despite the apparent risks.
I believe this was back when a certain workshop believed the wolf had superior fuel injection control and was able to flow more fuel through standard injectors vs say a powerfc using the same stock injectors. so the result was they kept trying to get more and more power on stock injectors and it went bang, like everyone said it would
  • Replies 49
hey guys sorry for late reply. i dont have the internet at home so im at work currently. will post dyno sheet up on weekend for u. YES the figures were extremely lean. over 13:1. It was done at hiu torque performance dyno day. i told him to watch the air fuel ratio coz i'd not had it dyno'd since after run in but the a/f's were way too lean. it run about 11psi then spikes to 15 at 5500rpm you'll see that in the gragh when i post it up. run was done bout 3pm in afternoon and was in 3rd gear. i havent changed injectors on it n its still running stock management(that i know of) although i dont have a speed cut anyway for some reason. theres always critics so i dont mind the critisism. anymore questions i'll be happy to answer
  • 3 weeks later...
2 pages full of doughters and only reply is he has shitty boost control???????
and possibly the worst graph known to man, if thats what you wanted? .... short of that one in the KKR thread though, thats even better and it HAS an ECU
Although, the boost delivery is extremely interesting as its only got the same power as the stock turbo for what, 85% of the RPM range, it only peaks in the last bit, so essentially the car really isnt any better than stock at all.
I suspect thats to avoid the mid-range shutdown that most people get when a car ramps onto boost with the stocker ECU. Its simply making a peak figure.
Mid-range = nothing
Low-end = nothing
Extreme high end = power spike
Which is totally uncharacteristic of the GCG hi-flows.
I bet if taken to the strip, the car wont run a much better time than that with a stock turbo :)
Got any figures/graphs from any of the other cars that day? :O
yeah i know im trying to figure out the boost spike issue aswell. boost controller was all the way down, suppose to run 7psi but it cant hold it. was at hi torque dyno day bro im not making it up. why;s it so hard to beleive?
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
