So i decide to service my car today (R32 GTR)....drop all the fluids etc etc. Go to undo the gearbox filler cap and RED yes RED oil comes pouring out the filler. Then drop the drain plug and even more. Undo the transfer case drain plugs...a drip comes out.
The transfer case is leaking (more importantly - pumping) ATF into my gearbox...has anyone had this experience??! No wonder it was hard selecting gears...
Gearbox is out...pulled the case off it cant see anything obvious. Can anyone recommend a good place to take my transfer for repair? Cos obviously the main seal or pump gasket is leaking...
The car has done 1,100km since a full rebuild, and the transfer was reco'd, i have no idea what is was like before.
Any help or experiences appreciated,
Cheers,
Mat.
https://www.sau.com.au/forums/topic/129547-atf-in-my-gearbox/
I bought a VS 5ltr 5speed many years ago when they were around 3years old, it had a shifting problem when cold (that I noticed upon test driving) and on higher than normal rpm gear changes (that I also noticed on test driving) they said no problems they will sort it out.
They being... 'au....... motors"
Upon purchasing the car I noticed the notchy, slight crunch and slip out of 5th gear was still there so I took the car back for warranty.
I got the car back and it was fixed. No more crunch and no more slip out of 5th. Later down the track it started slipping out of 5th, I discovered it was a factory recall and apparently a hub problem, they simply thew a stiffer spring in it. they put me off until it was out of warranty saying it was ok then once out of warranty didn't want a bar of me.
Interestingly the gearbox died just out of warranty (syncro's were shot and bearings stuffed) and upon dropping the gearbox oil it was discovered atf fluid was thrown in it. Bastards..
'The great great guys they were indeed'
The extended warranty I purchased with the car was not 100% honored as they stated the failure was caused by the use of atf fluid. So I had to shell out for half of the repair. ;)
it much oil can make it hard to change gear.. no matter what viscosity (sp) it is.
Thankyou for that - there is nothing wrong with my syncros! to have the oil of the gearbox AND the transfer fluid is way too much..
Anyways this is not about hard gear selection, tis about the transfer case and pumping fluid into the gearbox!
femno I guess the point is did you fill the gearbox, or did someone put ATF in before hand, and maybe the xfer case has a boring normal leak :P
Maybe its not ATF ?
You may have just drained an expensive amount of Redline heavy / light shockproof gearbox oil !
Just a thought.
cokey
Maybe its not ATF ?
Just a thought.
cokey
Just because its called Redline doesnt mean its red you know!
Does anyone who has replied here even know how a GTR gearbox/transfer arrangement works??
No one but me has touched the car so no, 'someone' hasnt put ATF in the gearbox....
*frustrated*
Um I don't know how the attessa works. I mean, I have only apart one of them, , bleed the system a few times, but apart from that, no, I don't know hwo it works.
I noticed that you joined the forum in March 2005.
I believe the question is do you know how it works?
We're only trying to be nice and help you out with possible reasons for why it might be like that.
Just like diagnosing any other problem, there is a series of steps you go through.
e.g. it is quite plausible that synchros might be worn after 15 years.
Also, redline does have a red shockproof oil.
What does this say abot me that i joined in March 05?? Seriously tell me id love to know. Maybe you could argue the fact that im 18 as well, some young bloke who doesnt know sh!t
And yes indeed i know exactly how the ATTESSA works. I also happen to know that on the front of the transfer it has it own pump and this is where i know it is leaking from, pumping into the gearbox where it fits onto the output shaft.
I have no issues about the operation of the system...jus wanting to know if anyone has had this problem before and where the best place is to go and have this rectified.
Im not having a go at anyone and i know that people are only trying to help me out and this is very much appreciated, thankyou all. But you cant blame me for commenting on the uneducated guesses im getting about this though.
Thanks again,
Mat.
What I was getting at is that you've been on the forums for 1 year.
Duncan has extensive knowledge and plenty experience.
My post above got stuffed up. What I was getting at is that I have actually rebuild a transfer case and bled several of them.
I was just saying that we were merely leading you through a process of diagnosis. I'm not saying that this is you, but many other people haev asked questions like um, ah, like how do I like bleed this etc.
Anyways, don't worry about it. which part is leaking?
Hey Femmidom.
"Then drop the drain plug and even more. Undo the transfer case drain plugs...a drip comes out."
Without the pump running what did you expect ?
I merely mentioned the redline oil because the stuff i bought was red !
Is the Attesa fluid reservoir running dry ?
I am well aware of how the system works and have a spare stripped in the garage.
You should look in the manual under Transfer Oil Seal Replacement !
THE PAGE IS NUMBERED CH63.
Also shows the position of the Pump.
If you dont find this helpfull , I cant help !
Chill Cokey
Note the only reason why people throw ATF into gearboxes that are not spec'd for it is because it improves the shifting quality of a f**ked up gearbox (due to ATF being very thin). Obviously ATF's additive pack is not suitable for gear/hypoid action and thus the box wears out even quicker.
This reflects in Cube's testimonial. Sorry to hear u guys got shafted. ATF is a quick and nasty fix.
I think you are getting confused with the pressure system part of the ATTESSA ie (reservoir in the boot, pump ontop of the diff), and the actual transfer case oil. There should always be oil in the transfer case...same as any gearbox.
No the reservoir in the boot is fine, at its normal level.
Anyway the leak is INSIDE the transfer/gearbox setup. No external leaks as such. The transfer has its own pump to circulate the oil inside of it, like the engine oil pump. This is where it is leaking from. Out of the transfer case pump into the gearbox.
I wont be looking up in my manual how to replace the seal because that is something i dont want to touch, id rather have someone who knows what they are doing fix it, not a 5 min job to take this in and out if u feel me...plus im not 100% its the actual seal, might be something else in that area, but wanna get it done properly.
So anyone know a good place to go to have this prob fixed? People that do transfer cases??
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
