Hi guys,
I have a Greddy oil cooler kit for sale. Details:
Greddy 13 row oil cooler core
Grex remote filter mount (incorporates thermostat)
engine take off plate
all braided lines and fittings (X4)
some brackets etc.
I bought this kit to use on my GTST, but it's not really needed for that car. I use the same kit on my GTR (very slightly different) and it's awesome so when I saw this one I bought it no hesitation. The thermostat keeps oil from flowing through the core until it's up to temp (so no worries in winter) and when hot it opens to let the flow through the core. The take off plate mounts a stock size filter (so no need to buy some stupidly massive holden truck filter like some kits) and it also has threaded holes (1 X 1/8NPT 1 X dash 10AN) so you can mount your oil temp or oil pressure sensor there (i use defi sensors in my GTR one with a trust adapter). This kit was from a 33GTST but I'm confident it will work on 32 GTR, 32 GTST, 33 GTST etc etc. It's just a matter of finding a position to mount it. But the take off plate will bolt on no problem and the core is designed to bolt in front of your radiator.
Kit retails around $1000. I'm after $490 for this used, good condition one. Pick-up is available in Sydney northside, or post it anywhere in aus at the buyers cost. I also have a spare sensor adapter that I bought for my other kit ( I stupidly bought 2 and only needed 1). It's brand new, unused. I want $20 for it.
Thanks,
R
pics below.
i made a typo (well, misread something), it is from from ECR33, not BCNR33 so I should have put 33 GTST not GTR in the above text (will edit now), BUT the kit should be exactly the same between the two models as it's radiator mount, not inner guard mount. I haven't tried to fit it to anything, but I bought it on the understanding it still had all the brakets needed to fit it, it certainly looks like it has all the needed bits.
You're welcome to come around over the weekend and take a squizz if you want mate?
hey beer baron,
what sensor adaptor are we talking about? is it a sandwich plate ??? or one of those bung screw in things that go into the sandwich plate?
Thanks
George
nah, it's a screw in fitting to go with the Greddy kit. Basically allows you to put a Defi sensor in the big hole in the side. ok, see the pic below, the thing circled in red is the filter mount. see the thing on it circled in green? there is another hole that size on the other side. It has a bung in it. The hole is too big for a guage sensor, so they make a new bung that goes in the hole and has a hole drilled through the middle with a 1/8NPT thread on it so you can use a defi sensor (or whatever) in that hole. :thumbsup: beside it is another hole that is already 1/8NPT so you can use 2 sensors in the same filter mount (1 press, 1 temp).
i'll take it off you.....i bought a greddy kit last month from nengun and the plate doesnt have te 1/8 thread but has 2 of the big threads just blanked out.
pm me your details
cheers
george
yogi, no worries, the sensor bung is yours.
oil cooler still for sale.
rkwk, reason being my GTST is still running:
stock boost
stock ECU
stock turbo
I was planning a lot more for it, but now I'm going to focus on the GTR, so GTST is staying stock.
I would suggest though that any light tune GTR that says even the odd track day should definately have an oil cooler. and they dont get much nicer quality than these kits. >_<
some more info.
Core is 13 row and 7.5 inch high (18cm)
2 inch thick (5cm)
13 inches wide (34cm)
The two short lines are 15 inches long (39cm)
The two long ones are approx 42 inch (107cm)
all measurements are approximate (just did them with tape measure).
Here are some pics:
I will take the oil filter kit at the asking price, as long as all the parts that are needed come with it to bolt onto a R33 GTR...
Are you sure the take off plate will fit a R33 gtr one?
Edited by Blitz_R33
no worries Jase, atm it's Blitz R33 in first. I'm assuming he will seal the deal tomorrow, if not my boy prank has next right of refusal. :no: I will post up in the thread when it's paid for and sent. :)
this is all done, paid for, and posted. sorry guys, but BlitzR33 was quick on the draw. :D
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
