lol ok ash. if you're going to nit pick at every post of mine, good luck.
I asked a question, hence the "?"
Because as khunjeng stated, the SAU stickers do not work the way other stickers with a backing sheet do.
Sarah put mine on fine, but she still didnt do it the way stickers with a backing sheet are supposed to work
And if your gonna try and assume things off every post of mine, then good luck to you aswell.
I have no idea what "sarahs" way is. Am i expected to know?
Your assuming i do know... and i most certainly do not :no:
  • Replies 50
Posted Images
i got paul's gf to do mine, , and she had to pick each letter off 1 by 1 and do it that way....
sorry, i thought i had typed it clearly enough in my post...I shouldn't have assumed you read the thread before posting :)
sorry, i thought i had typed it clearly enough in my post...I shouldn't have assumed you read the thread before posting :no:
as i said guys, i didnt have to do it that way for all of them, but it is certainly a safe and effective way to do it.
so far I have had a few themes come throuh...but none help my sticker efort. I have tried to peal them off slow and the thing just doesn't work damn it!
hard to say what the problem is then, possibly the user if so many people have managed to do it with no troubles.
but no one can be sure i guess
my stickers sucked! took a while to get them on. washed windows with the glass cleaner stuff. got the stickers onto the transfer sheet by sitting at the table with a rasor blade and slowly lifting the stickers off. didnt destroy 1. even the dot on the i came off.
anyone attempt this, i take no responsability for u slicin ur fingers off. :wave:
cyas tomorroz
in this thread is the only place I have heard of people not having trouble with those stickers.
The way I did mine, after I realized that they wanted to stick to the back sheet not the front, was peel it really really really really slowly, and when a letter starts to stick to the back get under the corner of it with a fingernail while you have as much of the two sheets on the letter as possible..
if that makes sense.. I suppose pictures paint a thousand words...
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
