All the ladies with skylines raise ur hand
  • Replies 179
4NGI3,
There are lots of newbies and other members who's cars aren't running scamming lifts, so why not you:D Just post in the cruise thread and usually someone close who has a spare seat will offer you a ride:D
See'ya:burnout:
ive seen a few around.
nice italian chick in thornlie in a black R33.
blonde in rocko in a burgundy R33
and two chicks who drive R32's
there's also a hottie in rockingham driving around in a KF TX3 4WD.
nothing turns you on more than seeing a hot chick driving a nice car.
Shaun
Originally posted by GTS-t VSPEC
4NGI3,
There are currently 3 female's in Perth SAU that are frequent visitors to cruises etc. Those being: Nizmo, Angel and Sneeza. And once Sneeza comes back from honeymoon she will most likely own a Skyline too:D
Joe, Please remove that photo before I have to kill you:p
See'ya:burnout:
well thankyou mr grst.. Miss me out! nice one! yeah i may not have a skyline but whats troys is mine and what mine is mine.. so really i own the skyline :)
Yeah Shuan have to agree with you there:D
Kyles, Sorry but we were talking about owners, and I haven't even seen you drive Troys car:D That doesn't mean that your not a very valuable member of the forum though, and I love having you along at cruises:D
See'ya:burnout:
Paul: you shoulda seen the the amount of people you scared in nedlands on wednesday(i think) when you took off down the main drag.
I just had a big grin on my face while all the old folks were hittin the deck.
hahaha big thumbs up!
Shaun
Originally posted by 4NGI3
Hey there, just a general poll. i've seen heaps of skylines in perth but i've never seen a chick in the drivers seat. just curious of how many of you there are :boobies2:
Just curious, do you think using the boobies picture will encourage women to come forward?
Don't know about Perth, but over in Syd we have a heap of active members owning and/or driving skylines
i was born in malaysia, my ancestors are chinese, so i can speak very fluent "engrish" and "chinglish" too! :P
ah finally, another kinda Malaysia but not quite...was getting kinda lonely with just me and SHUTO-BOY
Hey 4NGI3! yeah come on a cruise trust me there is always plenty of spare seats and ppl willing 2 take someone! We are friendly ppl and we dont bite (well some do:p)
Anyway i do know a girl who owns a skyline shes a friend of a friend and im trying 2 get her 2 join up shes hot 2!
Add me to the kinda-Malaysian-but-not-quite list too.
4NGI3, I'm trying to work out from your posts if you're female not. If you are, watch out for GTS-t VSPEC - he'll try and pimp you out in the blink of an eye. :P
Well, although she's not on the SAU forum, my wife drives the family GT-R on a everyday basis. Wine Red R32 GT-R with kids in the back. Still to come to a cruise, although we did drive (seperate cars) at the SilviaWA/SAU joint cruise the other week.
Cheers
Brendan
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
