Some recent pics of my r33, you may see the addition of a Bride racing seat aswell :D
Hey whats that little bit added to the bottom of the S2 front bar, have a seen it on a few others but never been able t find the name
Edited by Baconer
hey the s2 front bar is pretty f*ckin hot without the lights. where have you put your indicators though?
Hey dude, the blinkers magically appear when the car is in ignition.. lol
Na man the blinkers are in the sides of the headlights...
Thanks Dude! I'm not sure what type it is, it just came with it when i bought it. I'm still finding things out about it coz ive only had it for like 2 months... hehe
Ah same front bar that was on my R33 :( 3rd r33 ive seen with it.
Its a Bomex Front bar btw
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
