Clean and 'stealthy' looking mate... this is the style I like - simple... no stickers, RICE etc. Nice.
I would however, get bigger rims - but besides that looks nice and clean.
And oh, 1 more thing... definitely put the matt-black original lip back on - the CB one looks ghey!!
Thanks dude, but I kinda agree with the guys above, I wouldn't change anything about currently.
The CF lip looks average in the photos because you don't get that sense of depth and dimesion that comes with CF, its actually really 3 dimensional and looks awesome in person as its an unusual weave so its unique, but you don't see it so much in photos because it looks like a wierd chequered sticker, or some tacky fake stuff!
and as for bigger wheels.......what(?), you serious, they are 19x10.5's.....how much bigger do you want?.....20's are lame and too auto salon-ish on GTR's and you won't find much wider than 10.5!!!!
Your car is extremely clean neil, and the wheels look amazing. Well suited to the silver/tinted windows. I love it.
The photo quality is also great, they are some really high quality shots.
Thanks for the good feedback!
believe it or not the photos were taken with a Casio Exilim S770 point and shoot, not the greatest camera... Id love a DSLR. The car wasnt clean either...
Neil
Edited by mr_squiggle_1
its not that silly a question, it can be done i dont know all the ins and outs but its a YES :P
Are you sure you'd want to change the grill and bonnet, just to fit S3 GTR lights? :D
Not to mention that the headlights may not line up properly with the std s2 gtst bar.
The conversion is alot more easily done on a S1 gtst.
Very nice neil.
can you tell me the specifics of the window tint? it looks like the driver an passenger has a lighter shade than the rest of the windows. What are the percentages? Im wanting to do this myself.
To be totally honest I dont know. The tint was done when I bought the car. The rear window and fixed side windows are extremely dark, night time reversing is a nightmare! I dont think the tinting is legal as its alot darker then my S13 I had back in the day that I had darkest legal tint put on.
Neil
Are you sure you'd want to change the grill and bonnet, just to fit S3 GTR lights? ;)
would that be due to S1 and S2 bonnets being slightly different
he asked if S3 GTR go into S2 GTR, or can I not read properly?
the answer is yes if GTR to GTR.
there are few differences between the S1 and S2 R33gtst.
- Bonnet is diifferent: More squarish, has the lip.
- The "curve" of the headlights are different, not just the shape: s1 stick/curve out further than the s2.
- The bar is also different, as it follows the curve of the lights (ie: if you put a s2 bar on a s1, the bar tucks under the headlight; and vis-versa)
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
