thats clean as man. 8 years is a long time. what have you done to it so far?
What you see is what you get, its stock except for the wheels and the stereo. I've worked out that in the 8 years its cost me <$1500 in repairs that were not part of regular servicing. I've replaced the water pump, O2 sensor and the clutch to date, very very reliable car. Only thing that doesn't work is the arial which I broke off, I replace it with a 2nd hand unit but it was faulty so I just leave it up.
yeah its a cool pic. if i hadnt been driving at the same time it may have come out a bit better. heres a few of mine with the new camera
All good mate ;)
Nice pics, car looks clean as! Which reminds me, my car needs a cut and polish :happy:
Love the close up on the SAU sticker. :P
Nice 33 :(
    • Hi guys my TPS voltage is reading over 2v at idle.  My Haltech ECU is reading around 40% throttle position at idle also which is really strange. Note the actual throttle position sensor is brand new…    anyone have any experience with this or know how to calibrate it on Haltech ?
    • The OEM disk will not work on any AEM ECU, you need to use the one they made. You shouldn't have to flip the CAS or whatever you were describing, if you set the ignition sync offset correctly it can't backfire. Make sure you're using a spark plug lead on coil 1 instead of the timing loop to avoid weird issues with the timing light. Double check that your timing settings are actually correct, like is the 24 tooth configured correct or should it actually be 12 teeth for 1 crank revolution? I also found this: 305817248-AEM-Undocumented-Settings-v1-2.pdf
    • Yeah, I don't believe the M35 uses a deadhead system.
    • Have you done your thinking backwards? 3 bar, 43.5 psi pressure drop being the presumed specification for an injector, means you need 3 bar upstream when they are firing into atmospheric pressure, and more upstream pressure than that when on boost (you add your boost to your rail pressure to maintain 3 bar across the injector) and you need..... less pressure upstream when you have vacuum in the manifold. So, presuming that you're idling at -10 psi, then you only need ~23 psi in the rail. I realise that I did not need to say all of that to you specifically Matt, once you'd realised your mistake. It's mostly there for complete clarity for others.
    • Have you reached out to the guys at Spool Imports? They are a Ross dealer, I can imagine they would have the rings just sitting on the shelf (I could be wrong).
