Nope, just used a thin layer of matt black aluminum paint.
Powder coat is too think and will drastically effect the cooling efficiency of the fmic.
The blitz cooler i have atm is painted black, any idea what sort of effect it has on cooling?
Is the front mount powder coated Al?
The intercooler pipes are powder coated satin black (outside the engine bay).
Your cooler is sprayed with a really thin coat so that the fins don't clog up, shouldn't cause any problems. I ran 20+ psi through that cooler with no issues
Still seems to be holding well but i have not put any real power through it yet :P
Phone still great too.
Well i would be doing a bit of research on the type and brand of powder coat they use, wouldn't think it's the type of stuff generally used. Is the core also coated, or just the end tanks?
The whole cooler, end tanks and core
My cousins ARC cooler on his GTR is also powdercoated, same as my BLITZ one which W0rp3D has now and both are running with no issues
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
