HEY!!! nice. what did you use for the clear indicators?? and was it alot of work? ive been thinking about how to do this for ages....i really wanna get the glass spot light lens in there. but am pretty sure its an impossibility.
should come to the Carseldine meet tomorrow and show me :P
Edited by boiracer
what did you use for the new indicator? <BR><BR>my bad, just saw the above post
Haha sorry, i wasnt around the other night.
Its a piece of perspex basically, it was alot of effort without knowing where to go for materials etc
You need atleast 4.5mm perspex, and i just mounted it as a flat piece, but you can see the edges of the reflector so i had to paint a ring around the outside to hide them (pretty difficult to mask a perfect ring around it when its a slightly oval shape >_<)
But it was all worth the effort, and i like to have soething unique :P
Here are some Pics of my R33 GTS-T series 1 model . Took them on the weekend at a nice coastal town called Ballina . Thought i would share & see what people think !!
Cheers josh
Is it just me..........or is that a thin red wall on your front tyre? :whistling:
Yeah there is a red wall on my front tyres , the previous owner had that done to the tyres for some reason. Most likely for looks ! That will be gone by next week , i'm getting new Nitto Nt05 tyres for the front end :rolleyes:
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
