Found a pic in the forsale thread a while back when someone was selling black powder coated 350z wheels, looks great. Still not to sure if im keen on spacers though. Planning to roll my guards so it may have to be an option
good to hear from you Collen.
what's next for the car?
will you be checking in with us more often now that the snow's starting to melt up there?
Can't say enough about your car. I LOVE IT!
Edited by alex182
