Is that docking lol
f**kin love the front, granthem , did you have to cut up the front lip for it to fit ? Also did you use "liquid nails" to attach it?
Only had to trim the Lip ever so slightly because of the cooler. I was fairly impressed with the rest of the fit. No liquid nails needed, it fits so snug that it wouldn't need anything to keep it on! That said I did put 2 small screws in the wheel arches just to be safe.
Took a while to track down the kouki 4 door parts tho...
Grant, car's still looking good as always. And Nick, loving the awesome action shots of your GTR! That's definitely where a GTR belongs - on track.
Here's a recent photo of my car (the white one) and RBScreamer's freshly sprayed R33 in a custom shade of dark pink:
I love the aggressive fitment! What front lip are you running? Also diggin the pink one! GTS-t's represent!!!!
Is it a genuine lip or a Viva Garage copy?
Why does everyone buy Vivagarage, Genuine is nearly the same price before shipping. It doesn't have the same non roundy bits either.
I needed mine ASAP for a wedding. Couldn't wait 6 weeks plus for delivery so I bit the bullet.
The Viva quality is alot better then I expected. Required no trimming to fit the bar at all (like I said, only the cooler). That said I would have gone genuine through Jesse Streeter or someone if I had the time.
Who made the original in Jappo land anyway?
Edited by Granthem
Flat black on white, don't think it would work..white is easy enough to do with a spray can anyway and still look good..
Though dark charcoal or gunmetal grey does work well with white..
I'm wondering what satin black would look like against my gunmetal grey. :unsure:
Genuine gear is really strange. I like to think of japanese workmanship being pretty good, but even with big name companies it can be hit and miss.
I know a mate who got (from memory) Dmax carbon roof wing, rear lip etc for his S15. The roof wing is the worst for finish, fitment I have ever seen. Overall it is disgustingly bad and was purchased through a reputable shop as a genuine dealer I believe. That said, the lip was good.
That alone sometimes scares me from spending oodles on legit stuff I've never seen in the flesh.
here is a couple pics of how my interior has now turned out.
originally had r34 gtr front seats and r34 gtr steering wheel.
Now has Bride seats, door trims front and rear and momo race wheel with D1 carbon quick release hub
I built my own bolt in half cage seeing as i have the skills and equipment available at work (basically work payed me to build my cage seeing it was done during work hours)
i also got rid of the sound deadening in the back seat and sprayed the rear black
I have removed the climate controll, all audio gear and the factory centre gauges. made my own parcel shelf to cover all the holes left by speakers
fitted up igniton kill switch and other switches which still need to be hooked up
also fitted four gauges to the centre console
cage fab
cage paint
carbon centre pannel
gauges fitted
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
