Nice looker there Kevin.
Been a while since I've put an update in here myself. Sorry that it's so dark, I can't seem to get everything done in time to take some pics during the decent light of day.
After sporting a "clean look" for about 5 years, I've decided to go for something a bit different. Some will like it, some will hate it. I know. But I really like it right now and that's what counts.
Thanks buddy!! I like your train of thought; it's your car so as long as you like it who cares what others think.
Your car looks nice and is still clean. It's not like you have Nismo stripes going across the body!!
Good work mate. Rims suit too!
They are actually Lenso Project-D spec E Concave Wheels.
I bought them from Budi at Autotechnica here on the Forums. They are a trader and are currently selling the 18 x 9.5 version in black for $1000 a set.
I bought my Lenso Dish wheels from Budi too. Great guy to deal with, I recommend highly.
I have these pics on Photobucket, but the site doesnt allow to link them. Any suggestions on photosharing websites that are allowed?
Photobucket works fine, use the image icon at the top when replying and paste the direct link there it will work.
for example.
Thanks a lot buddy. I was using the HTML link I think. Its been a long time since I jumped on a forum. Hehe.
Like he said :)
Car looks good man, nice stance.
Cheers bud! :cheers:
Nice car, Impul front bar :thumbsup:
Cheers! Bumper does look alright without being too ricey I think. LOL.
Car looks great mate!
Cheers bud :cheers:
That does look good. Best looking bar I've seen on a Series 2 yet!
Thanks mate :D
Easily the best. I wish I knew that front bar existed before I resprayed the stone chips out of my stock s2 front bar! Great car man. :)
The bar on mycar also has two small cracks, I would like to also get it resprayed as well as the rear bumper.
Unfortunately, the car is up for grabs now :(
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
