Post Up Your R33!
nizmo_freek
Did you make the spoiler? or if not where is it from?
Bought it, pretty much just a piece of sheet metal that a wrapped in CF vinyl. Then its a case of taking 20mins to fit it with pop rivets. Few pic's floating around SAU if it and me getting it and installing it
  • Like 1
Lovely, what offsets and tyres are you running? Any guard work?
Looks incredible, great dish happening there.
18x9 +20 plus a 20mm bolt on spacer front & 18x10 +18 rear. Tyres are215 40 18 front & 225 40 18 rear & I have rolled the rear gaurds but the fronts have been rolled & pushed out a little.
Wish I could run wheels with those figures on my GTST but no one in my area does decent guard work. Thats a fair stretch on the tyres.
Plenty of camber I'm guessing?
Edited by GotsWapan
I have 18x8.5 front and 18x9.5 back on my GTST, cant remember the exact offset. No guard work at all. Get a little rub on the front of i take a bump to hard when turning. Rubber are 235 rear 225 front
Removed my plastidip and cleaned up my wheels today. Also bought some centrecaps that came in a machined finished, gave it a lick of 2k black with clear and put sticker ontop. black with embossed logo so the machine finish comes through. looks tidy imo. also some neochrome steel lug nuts. Just needs gloss black valve caps to finish it off.
the sticker on your boot is entirely appropriate
    • Got some decent progress after work yesterday and also today. Got the ECU all wired and passenger side interior all back together. Kept the wiring up nice and high to avoid people standing on it. Got the surge tank relays rewired and tidied up the pump wiring and cut a hole to bring the cables through.  I found a spare USB cable I had lying around so I decided to cut it up and see if I could use it for my CAN 1 bus. Turned out one of the pins I needed was to the shield of the cable so i cut it up and desoldered it and resoldered to the correct pins.  Had the issue with the powersteering hose hitting the A/C compressor and fan shroud. I pulled the bracket off and modified it to remove the front mounting point which now clears it all. Will keep an eye on it to see if theres any signs of fouling once it's up and running.
    • That's some good input mate. Nice.
    • So today I went well outside my comfort zone (again) to replace my valve cover gasket.  I have had a big leak over the exhaust leading to a lot of smoke and smell every time I drove it. The leak was in the rear driver's corner.  The job wasn't hard as such, just a bit finicky and time consuming.  The old gasket was rock hard and broken right where the leak was.  The leaky corner had so much sitting oil in it.  The good news to my amateur eyes was no buildup or sludge under the cover. It all looked fairly nice in there.   I haven't started it yet. I ran out of light and body when putting the coils and injector loom back in. Probs only 30min left for the morning.  I was so nervous putting the cover back on, I must have lifted it 5 times to make sure the gasket was still seated properly. God it's going to be nice to be leak free and not make other traffic light queuers think my car is about to explode.
    • Gave the Mazda it's first wash, it will need some clay, a light compound, and polish polish to remove a few swirl marks, but that will be a job for when I have a full day to get my DA polisher action on
    • Just did this job on my 32 with the boost doc kit. was quite simple to fit, hardest part was getting the rubber bungs back on the firewall. does anyone know how the heater will work now without the flap in the bend? Will I just have a heater on 24/7 now?
