I'm letting my pride joy go for $26000up for sale is my pride and joy, high powered performance gtst. which is also featured in the zoom magazine, previous owner had set this beast as a track car, also spending a lot of $$$ on it has one at import monster sau nats 2012 for quickest 800m mod 2wd class.
also at import monster sau nats 2012 800m highest speed mod 2wd class.
there is no back seats and carpet had been removed, has a bonds half cage $700 installed
has two r34 gtr bucket seats.
gtr rear end
omp race spec stearing wheel
a set of $700 defi din gage for oil,press,water,oil,temp
has a zetronic ethanol display screen $500
nismo gtr 320km cluster white $1000
phantom boost gauge $220
fully enginerrd certificates so hassall free
motor rb25 30 to4z turbo water and oil cooled
2000cc injectors areo flow fuel rail
all braided lines runs from engine to the boot and connects to a 5 ltr sard fuel surge tank with x2 walbro 450 in tank pumps
nismo in tank fuel pump to exterior
has an immobiliser built in too
x2 fuel location for exterior pumps
also has an e flex sensor so you can use petrol or e85 sensor and computer does the rest.
huge plenom with qhf 90 mm throttle body
Ross cas full balanced
drilled out oil remains blow off is plumped back
blisten shocks all new bushes
sway bars in boot engine bay under Neath sway bars
r33gtr wheels with brand be hankook tyres $1500 for set of 4
response head unit alpine speakers
brakes upgrade to dixcel type gs slotted rotors with zpads $2500
has also just put in a PPG dog box 1st to 4 gear straight cut 5 normal gear $8500
also has a nismo twin plate coper mix clutch but good friend jim berry had it supped up for me costing $3000 but strong guarantee it will last
r33gtr rear end 4:11
also eagle conrods, je pistons, custom exhaust camshaft (256deg) single coil up rated springs drain back vents on head drilled out oil returns rb26 cam covers with mines baffles external oil feed1mm restrictions full balanced QF45 throttle body high energy oil sump, tomei oil pump, factory Ross cass balancer, gready intake manifold, custom front mount inter cooler, Phoenix alloy radiator, custom 3.5 inch 5zigen exhaust system, high current igniter, link g4 plug in engine management system with link 2bar map sensor gready profec and electronic boost controller
the whole e85 fuel system cost $7600
car mad 450kw 601hp ran 11.08 at creek with old box be easy 10z with new box
car has receipt for every thing no joy rides no time wasters $27000 no less over 60k worth of grunt and power munches any thing on the road on low boost.
car also is featured in zoom mag custom plates SKYLNE also has 3 boost settings off is 14 psi low is 21 psi and a high 26 psi
call me on
0437797237
powererd and tuned by unigroup enginering!..
Edited by sime1
It needed a strong box, the big block sized torque ate the standard Nissan gear sets.
I see it also has FLEX fuel and supporting mods.
How much torque is it running now, do you have a dyno with torque and rpm, I would imagine it would be pulling stumps from 3k to 4k rpm.
  • 3 weeks later...
    • Yeah, I guess its pretty easy to get to if this doesn't work. Just wait till next oil change and pull it out. I am going to have to do the oil pan gasket soon and thought I'd just replace it while I was there.  Thanks
    • All that matters is you're safe and you were able to type that post. Hopefully heaps of parts you can recover for the next shell.
