  • 4 weeks later...
i took a video of my r33 i just got a question i can hear it at the start how the revs go up and down for the first 1 min it use to be like that for about 5 min i remember reading to clean something out (cant remember what its called ) so i did that and its better but still doing it is there something else could be wrong with it
could be a few things, probably best to post this in the correct section
Edited by defari
  • 1 month later...
  • 1 month later...
