After "Nurse Debbie's" little chat last night, you now all know why we need to give blood.
My next appointment (it will be my 94th!) is scheduled for after 30 August. While I ordinarily donate mid-week at the Bourke St centre, I'm willing to make a change to a Sunday at Southbank. To do this, I need your support.
If you are genuinely intertested in becoming a blood donor, please email me with your intention. I need to know by Friday next week (August 25) so I can try and organise a group booking on the 3rd or 10th September.
https://www.sau.com.au/forums/topic/130529-give-blood/
Reminder that some of us are giving blood Sunday (September 24) at the Red Cross's Southbank centre (Cnr Balston and Kavanagh Sts, South Melbourne). If you aren't giving, why not cvome along to lend moral support.
https://www.sau.com.au/forums/topic/130529-give-blood/#findComment-2510599
You need to have eaten something before you donate. I suppose we could do "morning tea" afterwards, although Red Cross supplies all those yummy nibblies after your donation.
And you need to have had a reasonable intake of fluids beforehand as well (NON-alcoholic, Brisby!!!!).
https://www.sau.com.au/forums/topic/130529-give-blood/#findComment-2513421
    • R34DE as in R34 with an RB25DE? So did you get this? Or you planning to?  I'm not really sure what you're saying.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
