  • Replies 184
Posted Images
I own one :D i think i am a girl.. *checks chest* Yep.. im a girl alright..
Haha *winks at bunta* ;)
Woot!
Give me a half share of the winnings Chris!
And to confirm Corinne...You are/were single and a boy had no influence over you choosing the car you have??
I own one ;) i think i am a girl.. *checks chest* Yep.. im a girl alright..
AHA PAGE OWNAGE!!!
Id be checking more than just the chest...
Ive seen them he/she's before!!!
You know with the women up top and man down below... :D
Rhinorebal works with a few also...
You know with the women up top and man down below... ;)
Oh there's no doubting Corinne, Col. She is one FIIIIIIIIIIIIIIIINE woman! And she has all the right bits in all the right places. How do I know? It's the women that Anna rejects that makes Anna the best ;):D
I was a single chick with a skyline (check avatar!)... untill last week when i sold it to buy myself a track car.
Can I still be counted so you win money?
L to the IZZO! You are a woman. A single woman. A single woman that own(ed) a skyline. You count. For sho!
P.S Have you been checking NS lately? There are so many 180's on there. And soooooooo cheap!!!
I'm a what now?
Yeah, daily, but I'm after a silvia, and they are all over priced! :D so just waiting for the right thing to come up...going to just get one with a blown engine and go from there. ;)
I'm a what now?
Sifnt buy the one I found you on thursday....SR20 5 speed manual, highmount turbo, suspension $9800
Woot!
hell no! my line is like my baby! hehe its my 2nd line! *starts to thrust in direction of car* hahaha!
haha you have been watching some fcuked up porn!
Oh there's no doubting Corinne, Col. She is one FIIIIIIIIIIIIIIIINE woman! And she has all the right bits in all the right places. How do I know? It's the women that Anna rejects that makes Anna the best :(;)
Haha :D
oOooh YEAAAAAAAA!
Ahahaha what a strange thread! But i'm not exactly a skyline owner, Dave. I owned one, but then Andy bought it off me, so that doesn't really count. Andy introduced me to imports 3 1/2 years ago, and since then, i've wanted a sileighty. Still do. By choice, I don't think i'd ever own a skyline.
I think it's sad how males think females only drive decent cars because of their boyfriends... we do have minds of our own you know :D
well a skyline, which you wouldnt own, is a decent car & a sileighty is really a silvia trying to look good buy putting on a 180 rear. so wouldnt that mean you'd only drive a decent car if your bf owned a skyline ;)
well a skyline, which you wouldnt own, is a decent car & a sileighty is really a silvia trying to look good buy putting on a 180 rear. so wouldnt that mean you'd only drive a decent car if your bf owned a skyline :(
Apart from your post making absolutely no sense, you really are a dipshit aren't you? A sileighty is not a silvia trying to look like a 180. It's a 180 with an S13 front. Or in my case, an S15 front. *sigh* I love the strawberry face look :( Just a sec, let me call my mum, she'd like to say something...
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
