When driving my skyline (R32 RB20DET Manual), as soon as i reached
the 2100rpm mark on acceleration, it sort of feels like its holding back but it jerks
forward like it doesn't know what it wants to do. When i put my foot down to
accelerate its ok, once past 2100rpm, not a problem.
https://www.sau.com.au/forums/topic/130905-car-is-hesitating-at-2100rpm/
are you still running the standard fuel pump? if so sounds like it is on its way out. from what i can read i beleve u have a bit of fuel surge as the fuel pump can no longer pump fuel fast enough, giving u that hesitation.
ive done plugs, last owner changed coil packs and now has the current 1s taped up and mine does the hesitating thing..... ive had it for 2 years, still does it, maybe the fuel pump..... but if it was on its way out, should of gone by now
I've now got a GTR pump in mine and that hasn't fixed the problem.
This came up a few times , so do a search on what it could be.
I think AFM , Injectors followed by OXY Sensors was the discussion
on those topics.
sounds like an AFM problem! car sort of bunny hops like its got no fuel then goes again... clean your AFM with carby cleaner. if that dont work try the AFM soldering there a DIYS here some were. or buy another 1. i just brought a used 1 and fixed my problem.
hope this helps
Its a R32 Skyline, RB20DET.
I did clean my AFM with carby cleaner and did the re-solder on it.
I think i might clean it out with the carby clearner again.
I'm running coilpacks, havn't got leads.
Coil pack normally has troubles at high revs.Put injector cleaner into the fuel tank,
see if that might fix it.Changing the afm to find out it did not fix the problem would hurt your pocket.
Any one got a working AFM to lend to see if thats the problem?
Where abouts are you?
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
    • What ECU are you running? This is probably the biggest question. If it's a PowerFC, I'd probably change the ECU and get something newer that will handle the injectors in a nicer way.
    • FYI: Racebox RE7R Custom Tunes Released!   https://goracebox.com/.../2017-infiniti-q50-q60-re7r-tcm...   FOR GEN 2 (21+) VEHICLES, PLEASE SEE NOTE AT BOTTOM See more   But whomever tuned your car is the tuner you should go back to, AMS, Sonictune or BT Tune....
