Because they do. They seem to have NO regard for the speed limits.
I was up that way this last weekend.
There I am sitting on 62 - 63 kmh in a 60 zone, and if I haven't got an idiot up my exhaust pipe, I've got idiots whizzing past me at 70+.
And I'm driving up the freeway to Newcastle, doing 100 - 115, and I 've got idiots - including P-platers - whizzing past me at 120+
So you guys have got nothing to complain about when you get done for speeding.
Oh, and if anyone spots a blue Commonwhore rego XX-777 (possibly with yellow wool 'wind-tunnel testers' on the rear window) - would you mind telling him his indicators don't work. I followed this dude for quite a few ks down the Hume, and not once when changing lanes did his indicators light up. Not even when he turned off to Canberra.
i drove to gosford yesterday and had a guy doing about 95 in the overtaking lane... i flashed (my LIGHTS) at him and he waved at me.. i drove a bit closer so he stomped on the brakes a few times.. come room to overtake him - i did... very quickly.
asshole. he had a fish (christian sticker) on the back window! shouldn't religious people be nicer and more courteous? asshole.
Originally posted by Duncan
Yeah, lots of ppl up here have problems with their indicators not working...really shits me.  I reakon not indicating is one of the more dangerous things you can do
Yepp, I've got to agree with that.
If someone is too lazy to use their indicators, it usually means they are to lazy to do a head check. And we all know how bad it is when your next to someone and they decide to take your lane and push you off the side of the road !!!
J
Saw an old lady in a 4WD with the side windows folded in. Old bag nearly swipped me. Move next to her to tell her what side mirrors are and she thinks I'm giving her the finger so she doesn't look at me.
And people reckon young drivers are dangerous! :mad:
The older they are the more dangerous they are... One friend of mine has a car which lost its mirror on the passenger side (possibly knocked off by another car) and when we were driving his mum to work in the passenger seat she freaked and asked what happened to the mirror...little did she know that she had been driving the same car withouts its left hand side mirror for over 2 months....
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
