IF ANYONE WANTS FREE HORSE POWER REMOVE THE RESTRICTOR FROM THE INTAKE PIPE LEADING TO THE THE SOLENOID BOOST CONTROLLER. TO FIND IT FEEL ALONG THE LINE AND YOU WILL FEEL A LUMP OF METAL IN THE LITTLE RUBBER HOSE THAT GOES TO THE BOOST CONTROLLER GTR'S HAVE THIS AS WELL.
THE RESTRICTOR LOOKS LIKE A LITTLE ROUND METAL PIECE AITH A HOLE IN THE MIDDLE.
HAVE FUN!!
I LIVE TO DRIFT IN FRONT OF COPS
https://www.sau.com.au/forums/topic/13129-free-horsepower-for-gtst-gtrs/
  • Replies 107
firstly take caps lock off
secondly it doesnt apply to gtst's
thirdly buy a bleed valve and up the boost properly. if you do some cowboy job like this you could cause the turbo to overboost, resulting in blown turbo and possibly engine damage from a lack of fuel/detonation.
SIKR33, can u provide some pics?? because when i boosted my series 2, i disconnected the boost restricter and fitted a pipe on without the bump in the middle.... its on most nissans and my friend did the same to his 200sx.... im sure i know what ur talking about, but if u can show some pics of what u mean that would be great!!
Boost restrictor? Nope.
And it is not the same as the GTR.
What you need is a restriction on the other side of the solenoid.I've done this and had the boost at 10psi (you still have a two step boost curve tho').
And if you want the boost to be 10psi for good then buy a cheap ass bleeder. Better still an EBC.
ADAM SERIOUSLY IF I WANT TO USE CAPS LOCK I WILL OTHERWISE MIND UR OWN BUSINESS, AND YES I AM AN AIRCRAFT MECHANIC AND THIS IS A RESTRICTOR AND NO IT WONT CAUSE THE TURBO TO OVERBOOST ALL IT DOES IS FREE UP THE VACUUM LINE TO ALLOW MORE BOOST TO BE APPLIED BUT IT WILL ONLY BOOST TO 7.5PSI WITHOUT AN EXHAUST OR WITH AN EXHAUST 10 PSI . GUYS DON'T WORRY THIS WILL NOT HARM UR TURBO OR MOTOR. ITS BETTER THAN CUTTING WIRE 53
Originally posted by Blitz
SIKR33: Lets try this again - turn your caps off.
You must be one sick aircraft mechanic, did you do word processing as part of your engineering training?
Do you have anything positive to add to the discussion? If not then leave your stupid comments to yourself.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
