IF ANYONE WANTS FREE HORSE POWER REMOVE THE RESTRICTOR FROM THE INTAKE PIPE LEADING TO THE THE SOLENOID BOOST CONTROLLER. TO FIND IT FEEL ALONG THE LINE AND YOU WILL FEEL A LUMP OF METAL IN THE LITTLE RUBBER HOSE THAT GOES TO THE BOOST CONTROLLER GTR'S HAVE THIS AS WELL.
THE RESTRICTOR LOOKS LIKE A LITTLE ROUND METAL PIECE AITH A HOLE IN THE MIDDLE.
HAVE FUN!!
I LIVE TO DRIFT IN FRONT OF COPS
https://www.sau.com.au/forums/topic/13129-free-horsepower-for-gtst-gtrs/
  • Replies 107
firstly take caps lock off
secondly it doesnt apply to gtst's
thirdly buy a bleed valve and up the boost properly. if you do some cowboy job like this you could cause the turbo to overboost, resulting in blown turbo and possibly engine damage from a lack of fuel/detonation.
SIKR33, can u provide some pics?? because when i boosted my series 2, i disconnected the boost restricter and fitted a pipe on without the bump in the middle.... its on most nissans and my friend did the same to his 200sx.... im sure i know what ur talking about, but if u can show some pics of what u mean that would be great!!
Boost restrictor? Nope.
And it is not the same as the GTR.
What you need is a restriction on the other side of the solenoid.I've done this and had the boost at 10psi (you still have a two step boost curve tho').
And if you want the boost to be 10psi for good then buy a cheap ass bleeder. Better still an EBC.
ADAM SERIOUSLY IF I WANT TO USE CAPS LOCK I WILL OTHERWISE MIND UR OWN BUSINESS, AND YES I AM AN AIRCRAFT MECHANIC AND THIS IS A RESTRICTOR AND NO IT WONT CAUSE THE TURBO TO OVERBOOST ALL IT DOES IS FREE UP THE VACUUM LINE TO ALLOW MORE BOOST TO BE APPLIED BUT IT WILL ONLY BOOST TO 7.5PSI WITHOUT AN EXHAUST OR WITH AN EXHAUST 10 PSI . GUYS DON'T WORRY THIS WILL NOT HARM UR TURBO OR MOTOR. ITS BETTER THAN CUTTING WIRE 53
Originally posted by Blitz
SIKR33: Lets try this again - turn your caps off.
You must be one sick aircraft mechanic, did you do word processing as part of your engineering training?
Do you have anything positive to add to the discussion? If not then leave your stupid comments to yourself.
    • Resizing injectors in Nistune can be done a couple of ways, and there are a couple of ways that you can make a mess of it. The tuner needs to be really aware of the effects of whichever approach he uses (either K, or TIM). They are both easy enough to "get the injector size right" to run the engine. But little details like old start enrichment and hot start are affected differently, depending on which boxes you check.
    • Pretty safe to say almost everyone that has tuned their own car has experienced this issue. The difference being that we have our laptop in the car and when it happens, it's literally 10 seconds of tuning to sort it.  Would you be happy to plug in your laptop and sort this yourself? It is a very simple process and there is no risk of harming your engine (if you are worried about that).
    • Yeah thats the next step now, either they wil or i will take out for a drive to work and go straight their after work and see is we get the same issues 🤞  thought i try my luck here too, never know someone else might have had the same issue but thanks for the reply
    • Basically your tuner needs to drive it for the 30 min (or whatever) to create the same conditions then check the ECU settings and sensors at that time. They may not be excited to because that takes them 30 min rather than just opening the bonnet and seeing the problem straight away.... Hot start is generally not as tricky as cold start, but there would be a table for fuel enrichment vs coolant temp as a starting point
    • Yeah, they all cant say anything for sure as everything is working fine . Said unable to find an issue untill it stops again. Could mist likely be CAS wiring or IAS valve issue but again not 100%
