Just sent my R34 GTT turbo off to GCG to get highflowed. Being doing abit of research and the max power is around 270rwkw from a R33 with cams. Mine also has cams ( tomei Poncams 260 ) and since the R34 has slightly larger exhaust housing... Is it safe to say that i should net 280rwkw with all the supporting fruit and a good tune? Now that would be pretty dam impressive from a highflow!
https://www.sau.com.au/forums/topic/131376-r34-gcg-highflow/
A 10rwkw variance can be attributed to Dyno more than anything dude.
The figure will be between 250 & 270rwkw depending on the happieness of the dyno.
Thats around what most people get, so thats what you will get. I dont think you'll make more than anyone else when you have all the same gear :O
If you do only make 250rwkw, doesnt mean there is something wrong (i can see you posting a whats wrong" thread if thats what it makes)
Just remember its a dyno, tuning mainly is the use so results of a 15rwkw variance are not uncommon... so aslong as you get 250-270, she will go quite nicely i think :D
Okies all dyno read diff..And many factors contribute to a final dyno reading i guess. But a highflowed R34 will produce more then a R33 highflow right? surley the bigger rear would make a difference to the reading after taking into account diff tune and dyno machines?
I believe the R33 your refering to making 270rwkw was with cams and the bigger vg30/r34 exhaust housing so effectively when you highflow yours it will be exactly the same size turbo.
as R31Nismoid was saying, the happiness of the dyno could already be the 10-15rwkw difference.
Some of my experiences;
Example 1
R34GTT with R33GTST GCG Ball Bearing High flow and standard Neo cams = 253 rwkw.
R34GTT with R33GTST GCG Ball Bearing High flow and 260 Tomei Poncams = 265 rwkw.
Gain from changing cams = 12 rwkw (up to ~20 rwkw at some rpm points)
R34GTT with R34GTT GCG Ball Bearing High flow and 260 Tomei Poncams = 275 rwkw.
Gain from changing turbine cover and tuning = 10 rwkw
That’s my R34GTT on our race team dyno, which is most certainly not “happy”.
Example 2
R33TST with R33GTST GCG Ball Bearing High flow and 256 Tomei Poncams = 260 rwkw.
R33GTST with R33GTST GCG Ball Bearing High flow with VG30 turbine cover and 256 Tomei Poncams = 273 rwkw.
Gain from changing turbine cover and tuning = 13 rwkw
Ian’s R33GTST on another dyno, since results collate, most likely not “happy” either.
You can draw your own conclusions from the above.
:D cheers :D
Edited by Sydneykid
Example 1
Example 2
R33GTST with R323GTST GCG Ball Bearing High flow and 256 Tomei Poncams = 273 rwkw.
:D cheers ;)
SK,
in example 2, am i correct in reading that you made more power with a R32GTST GCG Ball Bearing hi-flow turbo?
please clarify.
SK,
please clarify.
Sorry, trying to type too fast
I have fixed the original post, I think that answers your question.
At what boost level were those power levels reached SK?
1.3 and 1.4 bar respectively.
Dropped from 1.5 bar when we ported the cylinder head, less restrictions = more power at lower boost
:D cheers ;)
:D cheers ;)
hey SK,
thanks, that makes sense.
hey, actually, again in example 2, you state the same mods although with different power levels, that being from a different turbine cover. what turbine cover was that?
Example 2
R33GTST with R33GTST GCG Ball Bearing High flow and 256 Tomei Poncams = 273 rwkw.
they are all rated the same :rant:
i think the housing difference is very minor, just in the opening to the dump and stuff.
I think Bass Junky compared them... or was it someone else
Yer I did some measurements some time ago now, the R34/VG30 housing from memory was ~5mm wider.
I find it interesting how HKS tend to ran narrow skinny housings with a greater height where as the stock and garrett housings are flatter but wider.
hey SK,
Example 2
I edited it again to clarify, I thought the "Gain from changing turbine cover and tuning = 13 rwkw" told the story but it now reads a bit easier.
:rant: cheers :O
PS, my problem is so many posts and such slow typing speed.
Gary,
I'm curious...
The R34 and VG30 turbo's I had sitting here a while back were identical in general size not looking at comp wheel machining as the R34 comp wheel was considerably larger.
My understanding is that once the VG30 and R34GTT turbine covers are machined out for the GCG (high flow) turbine they are exactly the same.
:rant: cheers :O
Example 1
Example 2
:rant: cheers :O
SK what was the lag difference between the stock high flow and the one with the larger exhaust housing?
staring boost rpm and full boost rpm
thanks
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
